avatar_gooberliberation
P-47 Thunderbolt ideas.
Started by gooberliberation, January 26, 2008, 02:39:31 PM
famvburg
     I don't know of a 1/72 conversion, but ISTR a limted run kit or 2 a few years ago. I'm thinking something like Wingnut for one. I have at least 1 in my stash.
Quote from: Overkiller on February 18, 2011, 01:26:36 PM
Necrothread revival time folks....  :rolleyes: ;D
I've become rather intruiged with the final iteration of the Thunderbolt line, the XP-72....
I've found reference to a conversion by Koster in 1/48 that provides a vacform fuselage to be used with the wings and tail surfaces of the Monogram P-47, but does anyone do one in 1/72? Having said that, it could be a tempting subject to modify from a standard P-47 kit....hmmmmm....
Duncan
Doing a quick google search I found these XP-72 kits
Model Alliance Resin
CMK Resin
Wingnut Resin
KJ_Lesnick
An P-47 with F4U wings would rock...
Quote from: Overkiller on February 18, 2011, 03:24:54 PM
Ooooooh! Very nice Robert!  :wub:
Tell me more, is that a kit, or a scratchbodge?
Inquiring minds wish to know.....  ;D
Duncan
It is the Alliance Models 1/72 resin kit. When I got it it didn't have decals and it just had the four blade prop but I wanted to do the contra-prop version. I found that the spinner matched a Shackleton spinner from the Frog kit so I used one set up from the Shack' for this.  I also used some High Planes white metal P-47 u/c legs on it as the original resin ones broke as soon as I put them on.  I used a True Details P-47 cockpit tub and a Squadron P-47 canopy as the original wasn't very sturdy.
I had written to Hannants about getting some decals from Alliance Models because I had seen on the Hannants website that the later releases had decals, but he refered me to the owner of CMK who kindly provided me with a sheet from their kit.  I believe that the Alliance Models kit now comes with the contra-prop too.
I've since discovered that the scissor-links on the u/c should be turned 90 degrees towards the fuselage, I used some small diameter mig wire to make the set of gun barrels as the kit doesn't have any (I think)
Try Aeroclub.  He did handle some of the Alliance kits.  I've one together but not finished and it's gathering dust...
It's a nice but basic kit.  CMR standard of the early 90s.  IIRC mine had the contraprop spinner.
IIRC Alliance is another tentacle of the MPM empire.  Most of the kits they've released are ex Czechmaster.
While watching the TV News last night, I saw something very interesting.  It was a new Dodge Truck advert/commercial, and for the first 10-15 seconds it showed the XP-47H in flight.  The narrative was explaining where the Hemi engine in the trucks got it's origin.
gofy
The XP-72 looks like a way to mount a turbojet on a P-47.  (in the fat belly)
In my opinion, British, Canadian, or USAF markings make things look so much better...
gofy: Sharkit (by our member renaud) makes a kit of something very similar to what you describe: http://www.sharkit.com/sharkit/P47jet/P47jet.htm
Ed S
Quote from: pyro-manic on March 16, 2011, 11:39:03 AM
Definitely shows a family resemblance to the F-84.
Ed
Zaskar24
Quote from: KJ_Lesnick on February 18, 2011, 08:50:12 PM
Something like this maybe?
The biggest disadvantages would be the loss of a .50 Cal per wing as well as some range unless the tip tanks of the F4U wings were made self sealing and non-folding.  I would yhink that the F4U wing would help with prop clearance on take off and landing though with the bigger late war ones used on the P-47.
tomo pauk
The long-range P-47.
Fresh air duct scoop goes under belly (aft fairing also depicted), fuel 'stead of belly tunnel, more fuel behind pilot (like P-51, P-40). A shallower chin.
you might end up with something similar to the XP-72:
tomo pauk
Air scoop is indeed shorter @ XP-74, but still takes the under-wing space I've reserved for a fuel tank :)
