avatar_Mossie
Avro Vulcan
Started by Mossie, January 30, 2008, 08:59:55 AM
Quote from: PR19_Kit on January 26, 2014, 06:03:22 AM
a low and slow (and quiet.....) pass and then he pulled up her nose and opened the taps
Blimey, must have been low and slow if you means Mrs PR19's nose!  :blink:
Usually you plug your nose and open the taps, or else you'll fill up your sinuses  :thumbsup:
I just love the aeroplane. Love reading the stories and daydreaming. Wish I could go back in time to Waddo and watch her again !
We are supposed to be doing some work up in the Northern Penninsula of Newfoundland, and on the Labrador side as well. I'm hoping to somehow get over to Goose Bay and see the Vulcan there. Now that would be a dream come true !
:tornado: :cheers:
Quote from: kitbasher on January 26, 2014, 10:34:19 AM
Not HER nose, the VULCAN'S nose!!!!  :-\
Sheesh, you do get 'em around these parts.....  ;D
I googled it and it would be about an 8 hour drive from where we are to Goose Bay....that we be expensive with gas prices up there !
Hi Guys,
How many under-wing pylons could the Vulcan carry? I've only seen two, one under each wing. On the Airfix kit there are options for the Vulcan Bomber or Tanker.
I'm Whiffing a 1/72 Kitbash HS Vulpine- Airfix BAe Nimrod fuselage with Airfix Vulcan wings and 1/100 PlayFix Trident T-tail. Haven't decided if it will be a bomber, ASW or tanker yet. (wings have been fitted to the fuselage, fuselage halves glued together, T-tail spliced on.)
One pylon per wing for the production aircraft, but the proposed Phase 6 would have had 3 pylons per wing to carry 6 Skybolt. As these are pretty large (5 tons/11000 lb), you can carry multiple smaller items: 2 Shrike were carried per pylon for Black Buck, for a what-if, racks similar to MER (6 bombs per pylon) would not be out of the question.
Quote from: McColm on August 13, 2014, 08:06:55 AM
Erm ! are you sure ? I've got three Airfix Vulcans in the stash and none have a tanker option ---
Quote from: kitnut617 on August 13, 2014, 12:33:49 PM
Ooops I'm sure I've seen an aftermarket resin 'Tanker conversion'.
Quote from: Hobbes on August 13, 2014, 08:43:21 AM
Thanks
Quote from: McColm on August 14, 2014, 06:52:03 AM
I think you're right there --- I've seen one too.
EDIT:  Flightpath
I was just going to say that Geoff ---
Not on their website at the moment but there is one on eBay  correction, that's Hobby Search
Quote from: kitnut617 on August 14, 2014, 09:40:26 AM
http://www.wolfpack-d.com/htm/catalog72.html
Says it is at $40 WP72062
http://www.modelsforsale.com/catalog/product_info.php?products_id=686184-Wolfpack-Design-Avro-Vulcan-K.2-Conversion-set-for-Airfix-1/72-WP72062
One in the UK at Models For Sale
Airwaves did a K2 tanker conversion in white metal too, I have one. And it was a lot cheaper than $40!
Would that fit on the Airfix BAe Nimrod?
