F-16 and (Mitsubushi) F2
Started by Matt Wiser, August 15, 2004, 04:13:19 PM
Sauragnmon
Not sure I like the tailless delta concept, it just doesn't look right.  Though if that were the case, I'd just make it one big tank and smooth it over the tail and dorsal section, with a second fuelling port built into the top of the tank.  Go for broke and do it that way.
I dunno, I just like the look of the XL wing, and think it'd make a real cool strike bird project... if only I can find a conversion kit in 1/72.  I'm too damn broke for anything else without special sacred blessings from the finance minister.
elmayerle
Quote from: Sauragnmon on September 17, 2008, 08:18:08 PM
I don't know about the conformal tanks, they have that whole dip in the center that makes them not so conformal looking to me, at least on the F-2 Super Kai concept model there, though in hindsight, they don't look so bad with the dorsal avionics pod on the F-16I.
The dip is for area-ruling purposes.  The dorsal pod/fairing is present on all of your F-16D Model 50/52+ aircraft as there's just a need for the extra room.  Now if someone wanted to try something a bit different, there's the all-moving vertical tail from the original F-16XL proposal, the one that uses a F-16 horizontal tail surface as the moving vertical tail.
--Jane Wagner and Lily Tomlin
Sauragnmon
Hmm, not a bad concept really... full control surface tail.  Makes me wonder why it hasn't been done before.
Just call me Ray
Quote from: elmayerle on September 18, 2008, 02:11:58 PM
Since this dip is absent on the standard model, I assume it's to compensate for the missing tail? Most people who are aware of area ruling probably don't realize how "hidden" such measures are in modern designs.
It's a crappy self-made pic of a Lockheed Unmanned Combat Armed Rotorcraft (UCAR), BTW
Even Saddam realized the hazard of airplanes, and was discovered hiding in a bunker. - Skydrol from Airliners.net
Sauragnmon
I was thinking of making the CFT's a little more conformal in my case... slimming the forward profile down to ease the airflow over that damnable rounded brick hump, and then smoothing out that dip to make it a little more level with the avionics package in the dorsal pod.  It would look better, in my opinion, and I don't know if it would affect the airframe's drag effects, though I would imagine with the smoother slope it might work better...  I don't know.
Quote from: Sauragnmon on September 18, 2008, 02:48:32 PM
The idea goes back to the earliest days of flight and was used on many designs through WWI.
More recent exemplars are the NAA Vigilante, Lockheed A-12/SR-71, TSR 2 and the Tu 160.
Not much new under the sun.
Shasper
- Bud S.
My take on a super F-16 (has somewhat of a Flanker look I think):
Shasper
Do that with the F-2 and I think you're on to somthin' there . . .
Shas 8)
- Bud S.
tinlail
Quote from: GTX on February 13, 2009, 04:46:27 PM
I have the notion of building one of these with a ballistic missile hanging in the middle for air launch.
Quotefed by one big ventral intake
I was thinking of still using the standard F-16 inlets but in a quasi-Rafale style arrangement.
KJ_Lesnick
I like that twin-engined F-16 set-up...  I was thinking up an alternate Fixed-Wing VFX-WHIF...  I had thought of using the thinner booms of the F-16.  Putting two F-16 tails together ain't bad actually!
KJ
Scooterman
You guys are getting close to this.  Dunno where I found it-I had it in my profile stash.
Rafael
Quote from: Scooterman on February 15, 2009, 08:32:30 AM
Imaginary-wings: http://www2.tbb.t-com.ne.jp/imaginary-wings/
Worth looking at the CGI work of this fellow.
Rafa
1/72 Scale Maniac
YOU - ME- EVERYONE.
WE MAY THINK DIFFERENTLY
BUT WE CAN LIVE TOGETHER
Sauragnmon
So, I've been looking at investing in a Viper model now... and I had this... semi-crazy idea of whifbashing a whole whack of the F-16 modifications into One bird.  Here is as follows:
The base aircraft is going to be an F-16N - I don't know if that includes hook and gears, either way.  I'm wondering what External difference there are to the Block 60, as I intend to add the Block 60 systems into the aircraft ideally.  My next step will be the Diverterless Intake, as the 16N is a smallmouth and the 60 is largemouth, I know, so I'll go for broke with that.  Step three is the nozzle - I plan on notching the petals to give it the LOAN, and investigating what is required to give it the MATV/VISTA actuators for vectored thrust.
Thoughts?  Suggestions?
