avatar_McGreig
Kondratyev Fighter
Started by McGreig, March 23, 2008, 01:38:49 PM
McGreig
This is the first of what should be two projects for this GB, the Kondratyev supersonic fighter project. This was a real, but never built and poorly documented, Soviet project from 1953.
The fuselage comes from an old 1/72 Airfix Lightning F3, which I've had for years and from which various parts are missing. The wings, canopy and undercarriage are from a Leoman Su-9, the fuselage of which went to make an (as yet unfinished) Antonov fighter project. One set of tailplanes, which will become the fins, is left over from the Su-17 used for the VG Prowler project and the other set is from an old Revell MiG-29UB where I cross-kitted the Revell fuselage to Hasegawa flying surfaces.
There will also be a reasonable amount of plastic card, not in the photo, to deal with the removal of the Lightning spine, belly tank and lower rear fuselage.
I'm not sure what the armament will be - at the moment I've put in the Alkalis from the Su-9, but this may change and I'll probably add external fuel tanks.
Looks like a very interesting project, McG! Glad to have you joining us!
Ed S
This should make an interesting model.  But I was wondering if it was twin engined with the engines staggered or if it was single engine with the exhaust under the fuselage or it the extened tail housed a rocket?
Ed
Whoa! Now this could be fun!
Quote from: Ed S on March 23, 2008, 05:46:44 PMBut I was wondering if it was twin engined with the engines staggered ...
There were a number of early Russian jets that had that sort of configuration, so it's a logical way to go.
McGreig
Quote from: The Rat on March 23, 2008, 06:01:22 PM
Yes, it's a twin, designed around two AM-11 engines (The AM-11 was developed into the R-11 which powered the MiG-21).
I can honestly predict that this is a serious candidate to win :thumbsup:
Here's a couple of early Russian jobs with the same engine arrangement, from The Observer's Soviet Aircraft Directory by William Green and Gordon Swanborough, 1975. Unfortunately the book got a wee bit mildewed in storage:
McGreig
I've managed to make a start on this. There is still some minor filling and sanding to do, but the fuselage is now more or less done and I've test fitted one wing.
In the sketch the wing seems a little larger and broader at the tip. However, Soviet design bureaux tended to work within a framework of aerodynamic data and shapes created and tested centrally by TsAGI and the wing geometry of the MiG-21, MiG Ye-150/152, Su-9/11/15 and La-250 is almost identical. So I'm going on the basis that, if the Kondratyev fighter had made it to the hardware stage, the wing would have been similar in size and shape to the Su-9. (And, of course, I don't want to have to do any more work than absolutely necessary - - -)
Quote from: ysi_maniac on March 24, 2008, 06:43:34 AM
I agree with myself :blink:
McGreig
The basic airframe is now done, and the photos show the canopy tacked in place just to give an impression of the completed build.
However, there is still a lot of filling and sanding still to be done and I'm not sure about the size of the fins, which seem a bit small but also seem, to me, to be consistent with the fins in the original sketch
Gorgeous! Tail is a masterpiece of whiffery :wub: :wub: :wub: :wub:
It's coming along nicely!  I wouldn't worry about the size of the fins, many early jets had a smaller fin area to reduce drag.
Wow!  Real Dan Dare stuff yet utterly believable.  Can't wait to see this one finished.  ;D ;D
That's just killer McG! I love the sleek look which is slightly off-set by the twin rudders. Sweet!
thedarkmaster
really love this one, in fact i really love all aircraft which carry red stars.
but no it`s cool. what colour scheme are you going for ? natural metal or grey ? not sure what else maybe on offer for a service type ?
