avatar_lenny100
EH 101-Merlin Excalibur
Started by lenny100, April 09, 2008, 07:54:57 AM
lenny100
well for the first time i thought i show one of my build from start to finish.
this is also i believe the hardest build i have tried yet as many of you will see me try things i usually don't admit to.
here are the two kits i am using for this
the tiger kit
and the eh 101
lenny100
starting work on the internals
the rear will be fitted for transport duties such as the Hind but with a bigger squad load
lenny100
the first cut is the deepest
now the other nose
needs some more off to help with the blending
Ed S
That's a big difference in fuselage sizes.  I'm curious to see how this one turns out.  I should be interesting.
Ed
lenny100
work on the rear cabin
using this as a refrance
starting the paint job
Sisko
That is going to be a big step from one fuselage to the other.
My suggestion would be to widen the tiger front section and cut the centre out of the cormorant front section and bring the sides in.
This will make the two fuselages blend together a little better.
Just my 0.02c worth
Other wise I like the concept and will be interested to see where you go with this.
Get this Cheese to sick bay!
Just out of curiosity, why did you cut the cool sloping , tapering nose  off the larger chopper? You could just recess the gunship nose into it . Enjoy my unsolicited advice on how to build your model. ;D :party:
"The first cut is the deepest"   Boy, ain't that the truth?!  I like the way you bash plastic, man.  Go for it!   -_-
Its a bit like my own AH-90 Devil (as in Tasmanian Devil – it is also referred to as the 'Euro-Hind') assault helicopter - this is essentially a MRH-90 with the cockpit replaced by the tandem seat arrangement and nose cannon of the Tiger ARH :
lenny100
I have decided that the join will be used to carry a weapon area (probably some kind of large caliber gun system) to help fill up the gap on both sides.
What like rockets, gatlings, stuff on pylons! :thumbsup: Your a tease. :rolleyes: really looking forward to seeing how this progresses.
Good for you, if you are going to cut, cut big !  Keeping an eye on this build, for sure.
Quote from: lenny100 on April 11, 2008, 02:31:23 PM
This is clever use of the dissimilar shapes.
If you did want to put them together, however, here is a potential alternative for blending the dissimilar helo bodies:
You could cut the Merlin's "corners" using narrow isosceles-shaped triangle cuts (with the apex of each triangle towards the rear). This way, each "flap" of the forward Merlin could be bent inwards to better align with the more narrow front end.  I can sketch this for you if the text version is unclear.
You could start by making a card mock-up to simulate the existing Merlin's forward end that you can use for test-cutting to see what amount of material to remove from each corner.  That way you're not risking your helo model kit for the bleeding edge beta test.
Tip: To ease the inward bending of the kit's plastic, you can score/scribe a "fold-here" line on the inside of the fuselage to encourage the plastic where you want it to give.
Either way, you are onto a very interesting concept airframe!   :thumbsup:
lenny100
Quote from: John Howling Mouse on April 12, 2008, 07:46:48 AM
You could cut the Merlin's "corners" using narrow isosceles-shaped triangle cuts (with the apex of each triangle to wards the rear). This way, each "flap" of the forward Merlin could be bent in wards to better align with the more narrow front end.  I can sketch this for you if the text version is unclear.
I think i will give it a miss this time around but i will try this on a later project, as i fancy doing a stealth version using a Comanche front end and a mrh 90 rear, but i and i am sure quite a few other would like to here more on how to do this from a expert like yourself.
