avatar_Mossie
Flying Sorcery Inspirational Images
Started by Mossie, June 04, 2007, 04:01:10 PM
Greg, Scott's kitting the larger version you posted earlier through Fantastic Plastic.  The masters seem to be well on their way to completion.
http://www.fantastic-plastic.com/LRVCatalogPage.htm
Fantastic Plastic also does the USAF 40 Foot Flying Disc as well, master by Anigrand.
http://www.fantastic-plastic.com/USAFFlyingDisc-CataloguePage.htm
Jeffry Fontaine
#16
More fuel for the WHIF fires found at the Computer UFO Network on the WWW (http://www.cufon.org/).
Two links available for the Joint ATIC-WADC Report on Project "Silverbug" (Technical Report TR-AC-47, Project No. 9961, 15 February 1955).  There are some interesting drawings of what appear to be man-made saucer shaped flying vehicles that may have been built and flown.
Link to the Adobe pdf file: http://www.cufon.org/cufon/Silverbug.pdf
Web page link: http://www.cufon.org/cufon/silverbg.htm
Some more fodder:
Jet Pancake:
Sack AS-7/Me-400 as mentioned above.  Somebody put together a flying model with X-Plane & tweaked it till it flew well.  I might just do this one!
Sack AS-8, the guy that put the AS-7 together found torque was a problem at low speed so produced a push-pull variant, his own idea.  I guess another way to cancel the torque would be to use a contra-prop.
I'll PM Comrade Anatoly about this GB, as it seems to remain popular but keeps getting beat in the polls by the flavour of the moment.
Jeffry Fontaine
#18
Steve Payne created an interesting flying sub/spacecraft from the Testor's Roswell UFO and the F-19 Stealth Fighter kits.  Have a look at the build at this link: http://bellsouthpwp.net/s/t/steveplj2/modeltech/ff/thebuild.htm
For further entertainment, check out http://www.stopabductions.com/ it has complete instructions on how to build your "Thought Protection Helmet" to keep prying alien mind probes at bay.
Thought protection helmets, fantastic, I'm never sure if these guys or serious or taking the p!ss!!! :lol: :lol: :lol:
Quote from: Mossie on March 12, 2008, 02:49:45 AM
Menkin is deadly serious and used to work for Matsushita/Panasonic Avionics as well as Boeing. Some of the folks I worked with at Panasonic had worked directly with him and related that he used to preach his anti-abduction gospel at work.  :banghead: :banghead:
Jon
Chris707
A few ideas...
<img src="http://www.google.com/patents?id=dDB1AAAAEBAJ&pg=PA1967&img=1&zoom=4&hl=en&sig=SgsTQO-7Ga6jlwVGAw1TfEBVKYI&ci=177,963,568,315&edge=1" border="0" alt="Text not available"/>
ROTARY AND CIRCULAR SAUCER-SHAPED AIRFOIL AIRCRAFT  T. ROWAN
<img src="http://www.google.com/patents?id=kp5cAAAAEBAJ&pg=PP2&img=1&zoom=4&hl=en&sig=reyyjPNrR8UavMMhD5hAx2LQrNM&ci=161,311,564,325&edge=1" border="0" alt="Text not available"/>
CIRCULAR WING AIRCRAFT WITH UNIVERSALLY TILTABLE DUCTED POWER PLANT  Homer F. Streib
<img src="http://www.google.com/patents?id=BKtgAAAAEBAJ&pg=PP1&img=1&zoom=4&hl=en&sig=YbgmcpZ_quuq20M4F1T8Wh6WEd0&ci=283,634,468,293&edge=1" border="0" alt="Text not available"/>
VERTICAL TAKEOFF AND LANDING AIRCRAFT  Boyd et al.
<img src="http://www.google.com/patents?id=-BBSAAAAEBAJ&pg=PA1954&img=1&zoom=4&hl=en&sig=bNCYPyV7U1X7H5_BolsRsB5QXhA&ci=203,278,537,985&edge=1" border="0" alt="Text not available"/>
DISC AIRCRAFT WITH MULTIPLE RADIALLY DISPOSED GAS TURBINE ENGINES  Frost et al.
<img src="http://www.google.com/patents?id=zVpeAAAAEBAJ&pg=PA1958&img=1&zoom=4&hl=en&sig=InzX-BMJ_Vb_WacBT8xZx0Xv-s8&ci=213,253,471,153&edge=1" border="0" alt="Text not available"/>
DISC SHAPED AIRCRAFT  L. W. GRAYSON
<img src="http://www.google.com/patents?id=ApE5AAAAEBAJ&pg=PP1&img=1&zoom=4&hl=en&sig=2CMx6FXgX1_GbL9exzbJ3jELv1A&ci=329,858,397,507&edge=1" border="0" alt="Text not available"/>
Induction lift flying saucer  Kyusik Kim
Old Aviation Plans & Ads: http://paperofthepast.ecrater.com
I posted this pic in the inspiration thread some time ago.  I found it on a website related to that book, where it was named as a BAe Antigravity Aircraft.  I presume this is something to do with the Greenglow project, of which I wan't aware of until now.  I originally thought that the 'antigravity' application of the aircraft was a fantasy & that the vent was more likely to be for a more conventional lift engine.  Seems I was wrong.
If you wanted to build it, you could start with a X-32 forward fuse & scratch the body.  Anybody got any more information on Project Greenglow?
Here's a link to a page with several disc planes from prior to 1943, most of them were built:
http://discaircraft.greyfalcon.us/World%20Disc%20Development.htm
Quote from: Mossie on April 10, 2008, 11:57:09 AM
Facetmobile, a home built GA aircraft.
http://members.aol.com/slicklynne/facet.htm
A free paper model from Ralph Currell, I built this one few years back and had it until it was accidentally crushed.
http://www.currell.net/models/facet.htm
Jon
r16
#26
me too , me too but they will be have to be familiar
and a more serious version if I may call it so
[attachment deleted by admin]
r16
a much loved childhood memory while this is a from TV show that still befuddles me
r16
and one more
"Ford Motor Co.'s Levacar Mach I appeared in the Ford Rotunda in spring 1959. A full-sized prototype, this was an one-man "flying car" that was "levitated" several inches off the ground by three powerful air jets located on the bottom of its chassis. Planned to be powered by a small-scale turbojet engine, the Levacar was purportedly designed to reach a top speed of nearly 500 mph!"
pictures and text from Fantastic Plastic
Made out of simple plastic party plates.
