avatar_puddingwrestler
Puddingwrestler's Thundercat
Started by puddingwrestler, April 23, 2008, 03:05:11 AM
puddingwrestler
Gentlemen, you may call me insane (cries of "You're insane" from the peanut gallery), but I've decided that what the world really needs is a twin engine, floatplane P47 Thunderbolt. Called a Thundercat, naturally.
So I have taken up impliments of destruction and set to with an Academy P-47D and a old Hasegawa P-47D, and the floats from an Airfix Arado AR196 which I intend to turn into a land plane...
Behold: The incredible double-ended, push/pull twin floated THUNDERCAT!
There has been a little porgress past the point at which these pics were taken - the rear engine cowling is now glued in place as are the wings. They were only blu-tacked on for the pics.  Naturally, the float mounts will be modified a bit to fit this plane, so the angles will change.
And it'll be armed with as many bombs and rockets as I can strap on...
I'm having a little trouble coming up with a designation for the Thundercat - I don't fully comprehend the labarinthine US Navy system. Let's see... Fighter Bomber + Ground attack + Floatplane + Number + Manufacturer +          Number of lemmings required to push-start on an uphill slope + square root of commanding officer's ego multiplied by inside leg measurement of chief designer + intended theatre of operation.... er... FBGF6J-12-27.333-Alpha Centauri? Hmmm.... I think i went wrong there somewhere...
lenny100
Noe that a beautiful idea
why has nobody ever built it in 1/1 scale
puddingwrestler
Cause most aero engineers have a better grasp of aerodynamics/physics/reality than I do! :thumbsup:
lenny100
who needs to know about things like reality
I work on the word of the designer of the spitfire
" IF IT LOOK RIGHT IT WILL FLY "
Archibald
Or Dassault, "Si un avion est beau, il volera bien" !
Interesting idea btw!
Quote from: lenny100 on April 23, 2008, 03:29:00 AM
Well, if you throw it fast enough, it will...
lenny100
if they can get a bedstead to fly................................................
Ed S
Interesting.  How do you plan to make the tail?  Is it going to be twin tailed?
Ed
This is a very cool concept PW! As for lateral control, may I suggest wingtip rudders like those on my Cabal Bolide II?
Why not combine the landing gear and a rudder? Spats, and on those spats, a rudder :drink:
Patrick H
QuoteGentlemen, you may call me insane
don"t know about the rest of the gentlemen but I sure do  :lol:
But hey, you do fit amongst the crowd here and that thundercat looks superb.
Looking forward to see the finished bird
My webpage
puddingwrestler
It will have a twin tail out on booms; otherwise it just seems to look to short. The tails will be on V-angles.
puddingwrestler
More porgress!
Quite a bit of the old PSR going on - using Tamiya grey putty to blend the rear engine cowling into the belly - the upper engine cowling is bieng left open as an air intake. I figured it needed one! I've also glued the landing bay doors on and puttied them up. One of them has been re-puttied as I didn't use enough. I've also added the lower vertical stabiliser. This was cut from the Academy P-47, flipped upside down, trimmed a bit and glued on. I've got some pics here of the machine resting on the floats. I have not modified the float mounts from those used in the Arado, so the angle is all wrong, but you get the idea. Also got a shot of the plane just sitting on it's floats with the tail fins in thier approximate positions.
puddingwrestler
The Cabal Bolide II is a very interesting idea, however it's fuselage is a lot longer than the Thundercat's. If I went with wing tip fins, the 'cat would be wider than long, and that just looks all wrong to me. Except in a flying wing, but the 'cat doesn't have that sort of wing.
Hmmm.... maybe that should be my next project  :wacko:
Sisko
Can't wait to see where you go with this one.
I bet the pilots would nickname it the blender.
Cause thats what's going to happen when you bale out of the thing!!! :wacko:
Get this Cheese to sick bay!
