avatar_Hawkeye
B-36 kitbash
Started by Hawkeye, April 29, 2008, 10:18:09 AM
The Wings look great, sort of makes it look like a combination of the B-36 an the B-46. Nose would need to incorporate a Radar instead of gun turret and maybe change the canopy to possibly a Vulcan or Valaint style teardrop blister.
G
I'm going to be the dissenter here, the canopy of the B-36 is one of its main identifiers and one of its coolest features.
Replacing the domed canopy with a stepped windscreen, fighter-plane bubble or V-bomber blister would be to exchange the unique for the commonplace and eliminate much of the aircraft's charm.
The furthest I'd personally go would be to possibly polish out some of the framing to reduce the number of panels.
Jon
Quote from: puddingwrestler on April 30, 2008, 09:45:10 PM
An OPEN COCKPIT ala WW1!
And spats, T-tail and Canadian markings!
Exits amidst a hail of cheers from certain members of this forum! ;D
I'm with Jon on the canopy, but I do agree the nose would need to be reprofiled to something a bit sleeker, something like a B-47 nose. Maybe a small bombaimers window in the lower half.   It wouldn't need a radar though, it's got a honking great big one just below the forward fuselage and is also just part of the B-36 profile that identifies it as such.
CanisD
I'd keep the canopy as is, maybe modify the nose to the configuration of the B-60, similar to the B-47. I'm wondering though about the tail. With the new wings, they may look a bit out of place as is. Something more B-60ish might work, though I'm not sure where you could get them from unless you scratchbuilt them. B-52 might work...
"If you want to have dinner with the Devil, make sure to bring a long spoon!"
Wolf's Shipyard
Wolf's Shipyard Forum
Quote from: Hawkeye on April 30, 2008, 12:20:14 PM
Quote from: Ed S on April 30, 2008, 11:10:30 AM
Looks like a great idea.  Are you going to sweep the tail surfaces as well?  It looks like it could be part of the RAF's "V" bomber series.
Ed
That is the plan. I've even toyed with doing a twin tail or T-tail configuration. Nothing like re-engineering the whole thing!
How's about a V tail, a la Dale Brown's Megafortress ?
Hawkeye
Quote from: Ian the Hunter-Gatherer on May 01, 2008, 01:27:31 PM
Ed
You mean like this?
I built the "Old Dog" out of two Revell 1:144 scale B-52s. I have more pictures around somewhere...it turned out real sweet.
Gerald Voigt
noxioux
Quote from: joncarrfarrelly on May 01, 2008, 06:29:26 AM
I have to concur with Jon.  If you made this thing look too modern, it would totally loose the charachter of the time period.
But any way it goes, this is one I'd really like to see completed!
Hawkeye
When I do a kitbash I try to use as much of the kit as possible. The tail and horizontal stab will be reused though reshaped. Like here where I used a stab to make a canard for another project.
A little cutting and splicing.
The canopy will remain pretty much as is, but I will remove most of the "greenhouse" from it. The nose will be a combination radome with limited glass area.
Gerald Voigt
I really like your Old Dog! I did one myself, from a later book.
    Eddie
http://img.photobucket.com/albums/v669/scurrfy/models%202/Apr08359.jpg
Hawkeye
Quote from: Eddie M. on May 03, 2008, 06:31:27 AM
    Eddie
I have two 1:72 B-52 kits set aside to do one up in full detail. It is just a matter of getting motivated to do it. Probably wouldn't hurt to read through the books again to spark interest again in the project.
Gerald Voigt
I've even toyed with doing a T-tail configuration.
Um, did somebody say "T-tail"?????
When I first saw the subject title of "B-36 kitbash" I thought, "Well, that's something you don't see everyday!"
As a project in this scale, your idea even sounds intimidating but I sure hope you keep at it.  Take the plunge!
And keep us posted....
thundereagle1997
Imagine a B-36 with turboprops & high bypass turbofans to improve it's performance & payload.
I think that's McColms department.
Turboprops with pusher propellers could be tricky.  Where would you route the exhaust?  Maybe through the centre of the spinner?
Quote from: zenrat on June 22, 2023, 04:32:52 AMI think that's McColms department.
It'd be a bit complex to achieve but would be do-able, & would be your best option, too, I think.
