avatar_Daryl J.
Hawker Hurricane
Started by Daryl J., May 03, 2008, 03:06:28 PM
Hawker Fury Monoplane with RR Goshawk engine.  Interim design step between the Fury & Hurricane.  If you delete the spats & draw a straight line from the cockpit to the base of the tail, you've nearly got the Hurricane prototype.
Was that a private venture or did the MoD of the time request it?
IIRC, it was a private venture.
"Visit Scarfolk today!"
dogsbody
Quote from: Mossie on January 30, 2012, 02:14:08 AM
Kinda looks like the Estonian PN-3.
http://www.airwar.ru/enc/spyww2/pn3.html
with a uniform to wear,
a fast aeroplane to fly,
and something to shoot at?"
Did they ever try a Griffin in the Hurricane?
Martin H
Ive seen drawings for a Griffin Huricane, but I dont think it ever got any ware near metal work.
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
There were plans for a Hurricane with a hood and cut down rear fusalage rather like a Spitfire for intruder ops, but not a true bubble as far as I know. Ysi's profile shows just how preaty that would have looked  :thumbsup: If a warplane can ever be preaty
As for Griffon engined, as Martin says there was a plan in 41/42 but it wasn't built. Likewise there were plans for Hercules and Dagger (one I intend to build) engined examples if the supply of Merlins was restricted
A Hercules engined Hurricane sounds almost obscene to me, but such a thinking produced the Fw-190 and that didn't look too bad I guess.
Martin H
Omega resins did a number of odd Hurricane kits. Ive got two of the Hercules Hurricane in my stash, and the Yugoslav one with the Daimler-Benz.
Unfortunately,
There's an engineering reason why the Griffon Hurricane was a none starter, something structural, but I can't remember what it is. Something to do with wing spars, I think.
perttime
A quick search found a plausible explanation why they didn't put a bigger and heavier engine on the Hurricane:
"To accomodate the Griffon would have meant a massive redesign, including bringing the wings forward by raking forward the stub spars. Camm had the drawings ready, but was told that there was more potential in the Tornado/Typhoon series"
http://www.ww2aircraft.net/forum/aviation/griffon-powered-hurricane-29321.html
My interpretation is that this refers to CG issues.
Also:
"Sydney Camm - - - said he might have made the Hurricane faster by tweaking the wing, but he knew that war was coming and he didn't have time for much fine-tuning of the design. The very fastest Hurricanes ever built, some PR (photo-reconnaissance) versions, had a speed of 350 m.p.h., there was only so much that could be done with a plane with such a thick wing - - -"
Would it be worth to install Typhoon wings in Hurricane? Were they thinner?
Tempest wings would be better as they were a LOT thinner, but a Temptest already was a 'later Mark' of Hurricane.
Hawker didn't follow the same 'develop it till its eyes pop out' path that Vickers-Supermarine did with the Spitfire. Hawker built an almost new aircraft each time, thus the Tornado, the Typhoon, the Tempest and the Sea Fury in turn.
The option I was thinking about is kind of a retrofit: To install canopy and wings taken from Typhoon production lines to upgrade Hurricanes. :wub:
For export perhaps. :wub: :wub:
