avatar_nev
Grumman TBF and General Motors TBM Avenger
Started by nev, May 17, 2005, 11:51:48 PM
SinUnNombre
Hey guys. In correlation to my recent Turboprop P-47 thread, its time to breathe new life into the CAS Avenger project. With my search for a turboprop for the P-47 coming up, well, disapointing, I'm thinking of just sticking with an air-cooled radial, but using an R-3350. Now, he only 3350 I've currently got is part of my Avenger kitbash, but I was wanting some input on an idea I've been rolling around in my head for a few minutes. What if I took the 3350 for the P-47, then used either a Double Mamba or T-31 turboprop on the Avenger? Since its destined for an older theater and I'm not as concerned with keeping it looking pretty, I think that it would work, and solve my issues. What do you guys think?
Jon
R-2600-20
TBF-3, TBM-3
Diameter: 54.09"
Length: 66.08"
Weight: 2,045 lbs
R-3350-26WA
AD-2, 3, 4, 5, 6
Diameter: 55.62"
Length: 80.81"
Weight: 2,848 lbs
R-3350-26WB
AD-7
Diameter: 55.62"
Length: 81.23"
Weight: 2,953 lbs
Another turret option is that of the Douglas A/B-26, I test fit one from the Monogram 1/48th into a Accurate Miniatures TBF... loads of room.
Mount the gunners seat, facing aft and the gun control parts between the turret and the pilots seat in the Avenger.
Cheers, Jon
royabulgaf
Since you want to use 20mm cannon, perhaps bag the Avenger and go with a COIN Helldiver?  Their wings were set up to handle 20mms, and the A-25 variant was modified for land-based use with a more suitable landing gear.
Kim M
Jeffry Fontaine
#48
After seeing the images and general arrangement drawing of the Columbia XLJ-1 that Jon provided in two topics
Links to both topics:
Turbo-Loening http://www.whatifmodelers.com/index.php/topic,15599.0/highlight,columbia.html
F6F Hellcat WHIF Ideas http://www.whatifmodelers.com/index.php/topic,17681.15.html
I could not help but notice how much that aircraft looked like a kit bash between the Grumman Avenger and Duck.  So I was wondering what that would look like?  No chance of a Duck being merged with an Avenger in the same scale so maybe a scale-o-rama would be necessary.  Using a 1/72nd scale Avenger and a 1/48th scale Duck to create an amphibian Avenger.  Obviously the bomb bay would be lost in the conversion but you would end up with a rather largish amphibian cargo and passenger aircraft that could have filled a niche in general aviation around the world.  Some possible civilian uses could be as a water bomber or a bush plane operating a passenger and cargo service to the remote reaches of the Pacific North West, Aleutian Islands, and the Artic where landing on a lake or the ocean would be the only option.
QuoteI could not help but notice how much that aircraft looked like a kit bash between the Grumman Avenger and Duck.  So I was wondering what that would look like?  No chance of a Duck being merged with an Avenger in the same scale so maybe a scale-o-rama would be necessary.
Maybe a little like this perhaps:
Some real world Avenger mods.
The Yehudi lights reduced the detection range from 12 miles to 2 miles and would probably have been very effective in ASW warfare.
The single-seat conversion was made to evaluate the possible performance gains of the single-seat modification.
The two-gun turret installation was found to have a lower effective rate of fire than the standard single-gun installation as firing had to be interrupted twice as often to avoid hitting the tail surfaces.
Jon
My own interpretation of a developed single seat Avenger:
Another single-seater, this time a modified TBM-3 (BuNo. 69465) with a new canopy design.
Jon
Quote from: joncarrfarrelly on June 07, 2008, 02:38:42 PM
Jon
On a trip to Fort St.John (north east corner of British Columbia) some years ago, I past an airfield somewhere in the vicinity of Dawson Creek and Grande Prairie.  I saw an Avenger which had been modified like that Jon, it was being used as a bush plane or fire bomber, couldn't tell very well from the highway.
Turbo Avenger French (Alizé) and British (Gannet) style
Now I like those, especially the two on the left hand side  :thumbsup: :thumbsup:
For my tastes it runs;
1. Gannet-engined Avenger;
2. Alizé-engined Avenger, right on its tail;
3. Gannet-ised Avenger, right on its tail; &
4. Alizé-ised Avenger falling behind quite rapidly.
It'd fair hum along with the twin Mambas! :thumbsup: ;D
