avatar_GTX
Arado Ar-234 Blitz and Heinkel He-343
Started by GTX, May 30, 2008, 03:43:47 PM
It is true (or at least from the references I have), that the swept back 262 wing was more to do with CofG issues than pure aerodynamics.  The earliest proposals were for straight winged options - see below:
dumaniac
Greg - interesting facts - I must admit that the P65 is a conversion i want to do - with the nacelles mounted in the wing like a Meteor - I like it will like appealing.  In relation to the wing design, the straight wing was used by the He 280 so there must of been some merit in the design - Heinkel was no dummy - he just did not have support from above
Bernie
Howard of Effingham
would or was there a long wing span Ar-234 proposal dedicated to high altitude recon with either 2 or 4 engines?
i ask as the dragon kits for the type all seem to come with some cameras in the moulds and its a shame to waste them.
also i was wondering what might have been the precedent for our own PR19_kit's meteor PR19 model and figured the ar-234 was
good place to start.
trevor
Keeper of George the Cat.
Quote from: Howard of Effingham on September 20, 2011, 04:12:40 AM
trevor
Check page 1 of this thread, reply # 6.
Trevor,
The cameras are there because the 'standard' Ar-234B could be fitted out as a PR version.
The A version, the one without an undercarriage, made a number of operational PR flights when fitted with those cameras, and one made the first ever jet PR flight over the D-Day beaches in June '44. Apparently it covered more ground in one mission than all the entire previous Luftwaffe PR efforts over some days!
As for the Ar-234 being the influence for the PR19, that would more likely have been the Martin Baker MB8 Marln.....  ;D
This resurrected thread had me *HOPING* you have progressed on either your He-343 or "German B-52" whiff.
Any news??   :smiley: :smiley:
Howard of Effingham
thank-you GTX and thank-you PR_19kit! ;D
i hadn't thought of extending the fuselage quite that much, if at all. was looking at
extending the wings really and how to keep it looking right.
trevor
RussC
Teutonic Stratofortress! Lot of weight for a bird that lands on a skid or a narrow track bicycle undercart'. Kudo's for resisting the temptation to put turrets on it.
Like it!
Green Dragon
Was planning an extended wing and fuselage with the main landing gear built into the middle of widened engine nacelles. Thinking I may do Greg's Strato-Arado now, that's a cracker!
Paul Harrison
On the bench.
tomo pauk
#56
Quote from: GTX on June 14, 2008, 07:57:11 PM
Just as with the Me-262s a while back, how about a piston engined version?
Cheers, GTX - would you be so kind to add the second cockpit to this concept, turning this into a night fighter? Something sorta Me 262 canopy just behind the 'normal' cockpit, and some aerials?
tahsin
He was among the people who went over to the Beyond the Sprues forum.
tomo pauk
Quote from: tahsin on December 11, 2021, 02:07:47 PM
Okay, thank you.
Ar-234P with Ho-229 wings and engines.
... subtle differences... Not sure yet.
