avatar_ysi_maniac
US Army G-91, a tribute to BlackOps
Started by ysi_maniac, June 10, 2008, 06:07:15 AM
This may be lightly modified in a certain way.
I was SO close to building this one.... looking forward to seeing this one progress.
^^^^^ But please, do not stop. You would build it in 1/48 and I am absolutely sure your paint job would be superbe. :thumbsup: :cheers:
H*ll no !
1:72 Waaayyyy to small for me. Few years ago I built the 1:48 Occidental Gina just after it came out...... It is approximately 65% filler/30% bad language !
I'll leave leave this one to you  :thumbsup: Go for it.
^^^^ and I will not use the Revell kit, but the Airfix  :wacko: ;D I like to punish myself :party: :blink:
Update
Do you know? as I forgot to scratch build side consoles before closing fuselage :banghead: I had to add a pilot :thumbsup:
Security note: 2nd pic is blurred to avoid pilot identification ;D
Well I guess that US Army would load the simple and small Gina with tons of avionics, eventualy :thumbsup: I will consider A-4M as a modification model.
Looking very nifty Carlos ,are you eliminating the fuselage guns?
ahhhh, the avionics/ECM hub is a stroke of genius, Carlos.  Good call on that!   :thumbsup:
Quote from: sotoolslinger on August 08, 2008, 06:48:02 AM
It will have a pair of 20mm guns, like German version.
Almost looks like an A-7 with that hump, looking good Carlos!
Interesting project Ysi - right up my street!
Quote from: ysi_maniac on August 12, 2008, 07:46:25 AM
Wen't they 30mm DEFAs?
Good call on the avionics hump mate :)
Like the pilot as well.
Thanks to all of you!
BTW: I am thinking to equip this plane with two Mavericks. Would it need any bit to use them properly? I mean designators, rangefinders or the like.
A plane preferebly devoted to close support, flying low, would need a jammer?
Thanks,
Carlos.
PD: the nose will be configured as the nose of a Skyhawk A-4M
