avatar_Joe C-P
Fairey Rotodyne
Started by Joe C-P, August 07, 2002, 11:45:25 AM
KiwiZac
Here's some inspiration: BBC recordings of what the beast sounded like! Apologies if they've been previously shared. https://sound-effects.bbcrewind.co.uk/search?q=rotodyne
Zac in NZ
https://linktr.ee/zacyates
AMAZING that you found them Zac! And equally amazing that the Beeb actually recorded them!  :o Well done both.  :thumbsup:
But they're too quiet by around 50 db in reality, my ears weren't hurting like they did when the real thing imposed itself upon me in the mid 50s!
The 7th track seems the most realistic, the bang when the tip jets start up if pretty authentic, just too quiet.  ;D
[Later] I've just read right through this thread, fascinating stuff.
63cpe
Thanks you for sharing! This is amazing. I've always wondered how the ramjet at the tips would sound like once starting and at take off. But I was born too late and in a different country...thank you Zac!
David aka 63CPE
Steel Penguin
again thank you Zac.   at proper volume that must have been mind blowing!
Quote from: Steel Penguin on November 20, 2022, 01:47:56 AMagain thank you Zac.   at proper volume that must have been mind blowing!
Probably quite similar to some of the bands you listen to  ;)  ;D  :angel:
It's good to hear what a Rotodyne actually sounded like.  Albeit not at lifelike volumes.
Thanks Zac.
He made a good job of that, and not a mention of knackered clamshell door hinges anywhere.
It would have looked even better in the Landor scheme though.  ;D
I like that.  Interior is good.  Sanding the windows is a good tip although I feel if it was meant to be a later developed 'dyne they might have been a more modern rounded square shape.  So sand, fill if needed, polish, and mask.
Pictures confirm what I have always thought about the rear end - pig ugly.  A purely passenger 'dyne would not need the clamshells.
And I also feel a developed 'dyne would have obviously evolved tip nozzles and five blades.
So, things for me to be going on with.   ;)
Can you get model train carriage interiors without having to buy a whole carriage?
Quote from: zenrat on April 23, 2024, 04:54:49 AMI like that.  Interior is good.  Sanding the windows is a good tip although I feel if it was meant to be a later developed 'dyne they might have been a more modern rounded square shape.  So sand, fill if needed, polish, and mask.
Yes, I did off eBay
I've just had a thought about the rear end.
First class lounge bar with panorama window...
This is what I ordered.
Hornby OO Gauge BR MK3 TSD Standard Class Open Coach Interior Seating Unit
The original item is out of stock but that will give you an idea of what to look for.
Try Replica Railways site was well, they sell all the components for their ready-to-run models as separate items, and there's seven different coach interiors in their range, and they're cheap too, £2.45 for the most expensive ones!
This is their 'Spares Page', scroll down past the coach chassis and you'll find the interiors.
http://www.replicarailways.co.uk/mainsep1/menuspares
Quote from: zenrat on April 23, 2024, 05:39:33 AMI've just had a thought about the rear end.
With or without a Vistadome?
Can't you just use the toilet like everyone else??? :angel:
