avatar_Weaver
Northrop FA-5K
Started by Weaver, July 04, 2008, 11:56:14 AM
Doesn't look much different, but all the PSR is done, the u/c bays and door insides are painted up, and it has a new cockpit coaming to hide the control panel a bit more.... ;D The pylon and arrestor hook attachment points are masked up and the Sidewinder rails are fitted. The canopy is masked up, but I have limited confidence in the cheapo masking tape, so I don't know whether I'll glue it on tonight and give it an under coat or not... :huh:
This is the store I was talking about, which, unfortunately, I can't photograph very well because I don't have a suitable lens. It's a countermeasures dispenser based loosly on the Wallop Masquerade, which is basically a CBLS (practice bomb carrier) loaded up with chaff and decoy cartridges instead. There are 21 pieces in this little puppy - am I mad?  :blink:
Mad?  More like crazy (as in "crazy like a fox")!   :thumbsup:
crazy in a great way !    :cheers:
Bombed out on the rattle cans tonight, so...
If you can't win the game, change the rules: I was shopping for rattle cans because I didn't have an airbrush. To be precise, I did have an airbrush, but it was 20 years old, gummed up and missing bits, so as a last resort, I went into Hobbycraft to see if I could buy enough bits to get it going again. I couldn't, at least not for less than the price of a new airbrush, so....
I am now the proud and only slightly terrified owner of a new Badger 250, and some tins of paint that bloody well DO match that there boat...... ;D :blink:
ooooh ! Love the 250 !
Me too , the Badger 250 was my second airbrush , you will love it. :wub: :wub: :wub:
The Fask is now in the paint shop with an initial undercoat of rattle-can white going on (and I am now going to have to buy some more).
A pox on white-plastic model kits! Every damn bit of grey putty is acting like pre-shading and showing through - going to take LOTS of coats of white before anything else goes on....
Just a suggestion, but I'd try using a gray primer coat and then put the white over that. The gray should cover up the putty nicely and give you a nice starting point for the white top coat.
Amphion
I don't think the "white" in that camo-pattern is white, but rather a very light grey. If that helps any.  ;D
Amphion
Couple more coats of white did the job, ta. Finish isn't the best, but the clock is ticking....
Here it is with it's destined-to-be-white bits masked off:
Next, a bit of airbrushing practice, and then a coat of stone, (gulp) and then a trip to the LMS for some more thinners... :rolleyes:
Couple of coats of Light Stone with the airbrush:
Looking good, I always love to see the transformation that comes at the painting stage of the build.
Stone areas masked up. It's now in the paint shop with the first coat of topside grey drying. Not sure if the grey-over-stone is going to work or not, but it's too late to mess about now - running out of time! :o
