avatar_pyro-manic
Source for 1:72 Red Top missiles?
Started by pyro-manic, July 17, 2008, 05:29:37 AM
I'm looking for some Red Top missiles for a few projects, but there doesn't seem to be any aftermarket sets of them? I found a Lightning resin upgrade set by Flightpath on Hannants, but it only has two Red Tops, and at £14.50 it's just too expensive to justify. Are there any cheap-ish kits with a decent number of missiles (say four or so - I don't fancy having to buy two or three Lightnings just to rob the missiles), or are there any aftermarket sets around that I've missed?
Many thanks,
pyro :)
The old Frog Sea Vixen has four Red Tops AFAIK, you should be able to find the Novo, Eastern Express or Modelcraft boxings pretty easily.
Models for Sale have the Modelcraft boxing for a tenner:
http://www.modelsforsale.com/catalog/product_info.php?products_id=42363
You could also ask Colin at Freightdog, I believe one of his kits have/will have Red Tops.
You can pick up Airfix Lightnings very cheaply on ebay if you play your cards right. The Red Tops in them arn't a brilliant  molding, though.....
I am using my Airfix Lightning for my LSR project so if you want the missiles, I can send em to ya.
Quote from: Weaver on July 17, 2008, 07:51:04 AM
Don't Airfix Lightnings only have Firestreaks?  The Hasegawa/Revell/Eastern Express/Frog/Novo/Uncletomcobbleyandall and Matchbox F6s have Red Tops.   ;D ;D
Problem for Pyro is you only get two with the Frog Lightning, so Pyro will have to buy a shed load of Lightnings, unless (like philip), someone can top him up with a few.
This is my Airfix F.3 which has Red Tops, and IIRC the kit came with Firestreaks too.
gengriz
Red Tops and Firestreaks are fairly simple shapes (cylinder bodies) and therefore really aren't difficult to scratch build in 1/72, provided you can find the right diameter (approx) sprue as a basis.  Fins from plasticard (ice cream tubs, inkjet cartridge packaging etc.- make a cardboard template then try using a sharp pair of scissors to cut them up).
Damn - I've bought so many kits in the last few weeks I'm losing track...... :rolleyes:
Pyro - I've got THREE Airfix F.3s with two Red Tops (no Firestreaks) each. I only need four Red Tops for my Lightning F.13 project, so I can spare you two. With Philip's two, that should sort you out. They're not as bad a molding as I remembered either, just a bit short on surface detail.
PM me if you want them.
Doesn't the Matchbox Lightning come with them as well?  IIRC I gave mine to Lee (or Aircav)
