avatar_HOG
OOB Me109G-6 No Build-just tweak and blow or Lazy Bugger Build 1
Started by HOG, July 17, 2008, 05:10:42 PM
noxioux
I had an immediate, but fleeting urge to say, "ME109? (insert rude noise here). . ."  But after seeing that dio, my jaw hit the keyboard and broke my rude noise maker.
But if it was me, I'd stick the grass back in there.
Quote from: Brian da Basher on August 05, 2008, 02:18:43 PM
That's a Matrixone quality 109 you've got there HOG! Looks absolutely perfect!
:bow:
Agreed! TOO.
HOG
hOYHOY`L
Started to add the winter wash and gone waaayyyy  over the top. All that nice delicate spraywork has dissappered under a thin wash of sprayed white. Still its not unredeemable and I think I need to put some figures together before I go any further so as to see whats white and wots not awight, right  ;D
Thinking back to the original 1:72 dio, most of the "washed" areas are done in watercolour pencil (2 greys anna white) when I had got the figures sorted so you`d think I might learn somthink?.  :huh:
As an aside this was the sort of finish I was thinking of, another old dio in 1:72 of the Huma Hs132.
The streaky white on here is also water colour pencil.
Cheers :drink:
Gary
(Ralph Waldo Emerson )
Is the white overspray waterbased  :huh:  if so ,and I have done this before, you can actually rub it off manually with your fingers. It takes a while but try it.
HOG
hIYA SoTooSli`
Nah unfortunately its enamels all the way down thinned with cellulose thinners yet so slightly selfetched into lower paintwork/decal/plastic.  I was thinking if giving it a blowover of Tamiya acrylic clear before the white but.......... :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:  :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead: :banghead:
;D gary
wow looks like a Glaswegian karate school practise day   (Ken ye mather sew...then stiech theis)
McGreig
Hmm - - - despite the intimidating behaviour of the Glaswegian Martial Arts Gang, I have to say that I think this looks fine as it is.  :thumbsup: It looks close to the original 1/72 version and I prefer it to the Hs-132 (although that's probably just jealousy as my Hs-132 doesn't look anywhere near as good - - - )
HOG
Hi McGreig
Now I`ve had a day to consider my options on this build, it`s not such a disaster as I first assumed. The `white`coat is revell gloss enamel thinned as I said with enough cellulose thinners as to be virtually a wash coat sprayed as a fine mist at very low pressure through the airbrush. If you look closely at the pictures the white has taken on the appearance of a `fogging` coat over the original paint finish. What I think has happened is that due to the high amount of thinners the paint has seperated into pigment and gloss base resulting in the frosty fogged look with a high gloss top surface diffuseing the reflected colour to the eye thus giving this effect.
Therefore I think that by breaking up this reflective surface a suitable result may be achieced.
So I`ll bung on some matt varnish later an` see what happens. ;D
HOG
Bin there done that.
IT`S LATE AN`YOUR`E AN INVALID, WHY AINT YOU IN BED! ;D
Well I have a spaceship to build ..... what the hell are you doin ;D :lol: :rolleyes:
Besides I have catcrotch
HOG
Me     I`s still awake,its 04.35 uk time and o3.31 forum time. just found this when I went online for some reasearch on the109X.
Space ship looks fine but not sure about those front winglets.  Looks a little like an anime butterfly roboty thing.
Nitenite SoTooSli, hope that bloody big bedbug on your lap don`t bite
cheers gary :drink:
HOG
Hoyhoy`l
I think I can work with this.
Thanks to SotooSli for suggesting thinners onna earstick. I had tried white spirit and that never touched it but I rememberd a small bottle of nail varnish remover  (acetone) I had which with some 1200 grade wet n dry and an old fibreglass pencil got me back on track.
More as an when
Cheers  :drink:
Gary
Cool glad that worked ;D The winglets will have big effin guns on em :wub:
Looks like you nailed it to me HOG! Excellent!!!
:thumbsup: :thumbsup:
