avatar_Black Knight
ASW vulcan
Started by Black Knight, July 22, 2008, 11:37:44 AM
which ASW vulcan should i build?
1
8 (72.7%)
2
3 (27.3%)
Total Members Voted: 9
bexwh773
Thanks Black Knight, she'll be finished tonight for delivery to Dad tomorrow...... I hope  :thumbsup:
This guy here builds V Bombers for fun coz hes nuts but he knows their quirks: http://www.britmodeller.com/forums/index.php?showtopic=12409&hl=vulcan%201963&st=0
And Richard here had a whale of a time with his...... NOT :lol:  http://www.britmodeller.com/forums/index.php?showtopic=14915&hl=vulcan+1963
Hope they help
Bex
Becky aka Bex
Martin H
there was a proposed version with an extended rear cabin so allow 4 forward faceing back seaters, a loo, a galley and a set of bunks on the aft bulkhead. and every one sitting on bang seats. I built it earleir in the year, as a black buck (in comfort)
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Black Knight
hmmm this project might work now....
is it this one that you made?
http://www.whatifmodelers.com/index.php?action=gallery;sa=view;id=111
As The Dark Master rests, the Black Knight protects the New Commonwealth.
Aerotech, Keeping you ahead by any means.
Martin H
yep. thats the beast
Unfortunately,
Hammer
Last week I was reading up un the perspective "future" vulcans and one expected direction would actually be a large avionics "hump" picking up after the cockpit and going all the way to the tail, this could be interesting!
regards, Hammer
I look up, I dice, I mix, I chew, I blend, I spit it out!
elmayerle
Quote from: Captain Canada on July 24, 2008, 04:13:22 AM
As for the FLIR ( if that's what your asking about ) CDN Auroras ( and probably US Orions ? ) have a recessed one under the nose. What about doing something in between each engine ? Isn't there an ECM fit under one of them already ?
Yep, US Orions have them, even the EP-3E's have them though those may have a few other sensors there, too.
--Jane Wagner and Lily Tomlin
upnorth
Quote from: Martin H on July 24, 2008, 09:43:45 AM
I think thats the best solution to get the needed ASW system operators in there. This arrangement could also house the sonobuoys ahead of the weapons bay so that they could be reloaded in flight if need be.
My Blogs:
Black Knight
i think i will go with the extended cabin
Quote from: upnorth on July 25, 2008, 01:33:04 AM
but i don't get how this would work :unsure:
:tornado:
elmayerle
The only external evidence of the sonobouy launchers would be the pattern of identical holes showing the openings of the launch tubes.  See details of the P-3 Orion's launcher installation or that installed on teh EC-18 ARIA aircraft (much modified 707) for SIDS (Sonobouy Impact Detection System) use.
Black Knight
so i could just engrave them on to the bottom of the fuselarge?
martin you wouldn't have any in build photos of the b.3 would you? and what did you use to make the fuselarge plug?
:tornado:
upnorth
#40
Quote from: Black Knight on July 26, 2008, 01:21:23 AM
Most certainly. Externally, all you can see of the sonobuoy set up is just a series of holes that are flush to the contours of the fuselage.
Here's the sonobuoy area of a P-3 Orion:
http://data.primeportal.net/hangar/bill_spidle/p-3c/P-3C_161010_005.JPG
There's a couple of differently sized hole types for two different sorts of sonobuoys. In 1/72 the smaller holes are around 1mm in diameter and the larger ones are around 1.5mm in diameter. You'll also notice that the holes are oval in shape, this is because the sonobuoy chutes are instaled at an angle in the aircraft.
Drilling it in would be pretty easy, you'd just have to draw out a grid on the aircraft where you want the array to be so you can keep all the holes even and in line with each other.
My Blogs:
Martin H
:tornado:
Simple another Vulcan. or to be more precise, an old one that had ended its days on a model grave yard heap. It did need to be deepeded at the forward end thou, to match up with the new nose section. As for in progress shots......sorry didnt take any
Unfortunately,
Black Knight
hmmm, not so confident on buying 2 vulcans to make into 1 :huh: maybe some drain pipe the same diameter would work? :unsure:
:tornado:
Another option would be to cut the fuselage at the desired point, and extend it by building a sort of frame between the two parts. Then just add a skin of thin plasticard, and psr the joints before scribing some panel lines. A little more difficult, but a lot cheaper, and you don't have to sacrifice a second kit to do it. :)
elmayerle
If I might be so bold, I don't see why a combination of the last two approaches wouldn't work.  Find a dia. of plastic tubing, drain pipe or whatever, that fits the inside diameter of the fuselage and use it for the basic spacer with enough at each end to firmly anchor the cut sections of th fuselage.  Then use sheet plastic as pyro-maniac suggested to build up to the full fuselage diameter.
