M
can you guess what it is yet???
Started by mistress mannerheim, July 30, 2008, 09:21:37 AM
mistress mannerheim
stil needing lots and lots of work to get it ready for painting tho, heres progress so far after chopping, shortening, thinning, reshaping, etc, etc.  :banghead:
BAe P.110?  (edit: no, that doesn't have strakes)
AeroplaneDriver
I'm tempted to go with the obvious and say "F-18"  ;D but I wont.
P530 or F-17 maybe?
YF-17 based on the forward notch in the LERX, unless of course you are planning to fill them in to make the P530-3.
Jon
puddingwrestler
An F-18 that's been put on a diet and then run into a rather unfriendly, but incredibly dextrous laser cannon battery which has sliced it's wing off with incredible, indeed uncanny precision, captured on film just before it crashed as a result of only having one wing?
Damian2
Quote from: puddingwrestler on July 30, 2008, 03:28:54 PM
Damn it! He took my guess!!
D
Daryl J.
I think I ran.   But then again, maybe I walked.
Daryl J.,seeing something Persian
Looks to me like an F-17, are you going to do it as an operational version?
Howard of Effingham
it looks rather like an F-17 and a half!  ;D
here's to the end result  :thumbsup:
Keeper of George the Cat.
Wow that is cool  :mellow: You have taken on quite a project. I was just reading about the F-17  and thinking it was cooler looking than the F-18 :wub: :wub: :wub:
noxioux
I was afraid to guess, until a couple other people had. . .
This is a great idea.  It almost makes me want to suggest a "Y" build, where we'd all take a production aircraft and build the prototype.  Some would definitely be easier than others, but still, it might be entertaining.
It is funny how you start a project like this thinking, "What could be easier?", and later find yourself measuring your progress by counting the empty tubes of putty. . .
Wouldn't it be easier if you just bought this --- not to knock your kitbash though, MM:
http://www.anigrand.com/AA2023_YF-17.htm
Daryl J.
Cool!   I'd seen it as an Iranian F-5 derivative thus the "I ran" comment.
Daryl J.
AeroplaneDriver
The thing about building an "F-17" is that you raelly have a little bit of leeway.  If you assume that the YF-17 won the LWF contest, then you can make changes to the production F-17.  The F-16A was different from the YF-16, and in the same way you can make a production F-17A different from the YF-17.  It wouldnt be as different as the F-18, but still, it gives you a little room to maneuver.
Cant wait to see it progress!   :thumbsup:
