avatar_Flitzer
Me 262 HA 1a
Started by Flitzer, August 06, 2008, 02:45:50 AM
Flitzer
Hi all
just found a couple of pics of a whif I did a few years ago.
It was an idea of Igor of Unicraft.
Take the glass nose Me 262 (MPM) fuselage and marry to the wings and engines of the Ar234C (Revell).
Scale 1/72nd.
The project name we arrived at was 'Hoch Aufclaerer'.
Cheers
Peter
;D
Madness is the normal condition, only interupted by spells of sanity.
dogsbody
With the extra thrust, this one should go like stink, but probably not very far. With the extra engines, fuel consumption would be higher and with the front fuel tank gone there is less fuel carried.
Still, that is one nice looking aircraft and a great looking model.
with a uniform to wear,
a fast aeroplane to fly,
and something to shoot at?"
Flitzer
#6
Hi and many thanks.
Dogsbody.
I agree it might have been fast but duration would have been a 'once around the park' experience.
For the same reason one might assume the original glass nose Me 262A-2/U2 may also have had shorter duration than the 'normal' 262?
Maybe drop tanks or a belly affair, but where then would the bombs fit?
A folly I know ;D
Cheers
Peter
I really like your camo scheme on that beast, Flitzer!
Nice work!
Flitzer, as I remember the AR 234 I kitbashed had bomb racks under the engine nacells :thumbsup:
bexwh773
Now that looks very nice, I like that alot  :thumbsup:
ATB
Bex
Becky aka Bex
Patrick H
Great Job Flitzer. Wonderfull build and great job on the paintwork.
My webpage
HOG
hI fLITZER
nICE CREATION, wOULD YOU MIND IF i BORROWED THE BASIC IDEA ?
:drink:
gARY
(Ralph Waldo Emerson )
Flitzer
Stoolslinger
Quoteas I remember the AR 234 I kitbashed had bomb racks under the engine nacells
By jove I think you've found the answer to a more prolonged flight duration.
Put the bombs on the Ar234 mountings under the engines and add a slipper tank under the fuselage belly.
Or the other way round..leave the bombs in the original position and use the Ar234 mounts for the extra fuel tanks.
Great finx Stoolslayer.
And HOG
QuotewOULD YOU MIND IF i BORROWED THE BASIC IDEA ?
Not at all. Please be my guest.
Cheers
Peter
;D
Second guessing myself. You might have a ground clearance problem with anything under those nacells unless you make the legs taller .It looks fairly simple to use tank halves blended in on top of the nacells and wings. :blink:
