Glenn's Current Modeling Projects
Started by Glenn, September 02, 2008, 12:58:57 AM
All right, I apology... :-\
I just meant: removing one jet has already been performed by Glenn (while he added a nose piston-engine), I think he will not do the same again. Or maybe another asymmetric as both jet on the port wing and none on starboard? For some technical reason yet to find ;)
The other single-engined version is just the piston-engine in the nose and no jet, but this was the true first prototype, not what-if, sadly...
Glenn
Hi guys, today I'm back with the Glowplug, but now with it's port wing.
Scale : 1/144
Construction : S/B Balsa
Glenn
Congratulations - such a perfection in scratchbuilding, this is impressive... :thumbsup:
Quote from: Tophe on February 06, 2012, 07:59:47 PM
Agreed
Glenn
Hi guys.....today I'm back with the Samson from Avatar. This is the 1/35sc model and to date, have just started the wedge faring forward of the rotor mountings to the canopy.
Glenn
Wow! I wish I had your scratchbuilding talent, Glenn. Is this a balsa basis?
Glenn
No Tophe, it's based around an Academy 1/35 Huey. Converted and covered in balsa, bogged, sanded and varnished to the condition it now is.
Glenn
That Samson looks amazing, almost organic
Glenn
Yeah, it always reminded me of a giant dragonfly!
Glenn
Glenn
Back with the two acrylic flutes. Have since added the tube around middle and the pointed nose cone. At present is almost finished, construction I mean.....Once you see the model assembled, the penny should drop!
Glenn
Glenn
Back with the 1/48 B-45 Tornado. When I attached the port wing I found that it was too thick and couldn't set it at the correct angle. Had to cut the top layer down and re-think where I was going. She'll be big, even without the wingtip tanks, the span is 580mm.
Glenn
Great model but not easy... :-\ :thumbsup:
I am just sad that you may have to destroy old models to provide room for the new big ones. Or will you buy another house, a museum? ;)
Glenn
Lots of these aircraft models will be displayed hanging from a ceiling....where the computor is, that's 1/48. My bedroom is 1/144...mum won't let me display anything in her room, and the kitchen and lounge are both no-no's!
PITY!!!
Glenn
RussC
Sounds like the classic builders paradox. Our ability to generate display space lags our assembling powers.
