Glenn's Current Modeling Projects
Started by Glenn, September 02, 2008, 12:58:57 AM
Glenn
Back with Bessie and now with one wheel. Not even The Doctor could drive 'her' at the moment.
Glenn
Glenn
This started off as a V-2 rocket, a 1/72 East European model, and now it's the sub from Captain America. As it's only a one man sub, I'll scale her at 1/35.
Glenn
Glenn
Remember a while back, I showed you 1 of 3, and 2 of 3 model vehicles...but no 3 of 3? Well, this is it....starting off as a 1/32sc Pyro Jaguar SS 100......but, not any more!
Glenn
Glenn
If a G4M1 was known as a Betty....then a four engine version should be known as a 'Betty Grable' shouldn't it?
Glenn
Scale 1/144
Quote from: Glenn on October 21, 2013, 01:08:02 AM
Glenn
Indeed sir  ;D
Nice G4M/4m project! :thumbsup: Now I plan to draw a zwilling of it...
EDIT: I have done that at http://www.whatifmodelers.com/index.php/topic,20326.1530.html (this is faster than actual building but the result is far less impressive)...
Glenn
Well, you've had 1,2 and 3 0f 3....now you have the second generation of 1 of 3. The chassis has been constructed, and the radiator and tray in place, and you still have no idea what I'm building........good, all will be brought to life...eventually.
Glenn
Father Ennis
I have several of those trucks and I've had lots of fun with them,too. I've always had trouble with the cab not fitting together very well. I hope yours does better. I'm going to be following your build with great interest.
Glenn
Well, mine will be easier....as I'm not using the models cab at all!
Glenn
You're a busy man eh ! Love the big 4-engined bomber.
Father Ennis
Glenn
Recently, I discovered that Airfix had re-released the Angel Interceptor, and as I had a SAAB Draken..thought I'd do a Thunderbirds model.
I called the aircraft the Gyr Falcon to be used by the World Air Force.
Glenn
Interesting project, could you explain further how will you mix both kits? :unsure: :thumbsup:
Glenn
The German helicopter flies over the Alps to land at 'The Eagles' Nest', from the movie 'Where Eagles Dare'.
Revell M*A*S*H Bell 47G scaled at 1/35.
Tophe, with the Gyr Falcon.....the wing of the Angel and the outer wing of the SAAB are the same cord length.
Glenn
