Glenn's Current Modeling Projects
Started by Glenn, September 02, 2008, 12:58:57 AM
Quote from: Glenn on February 05, 2018, 06:44:37 PM
You cut it through the middle and make it that little bit wider.
That's what saws are for.  ;D :thumbsup:
As you can see, I stuck with the T-34 to make the Jagdpanther. Buying a T-55, I found that the hull is the same length as the T-34 but, (in 1/35) 4.5mm wider....so, what do you do? You cut it through the middle and make it that little bit wider.
Glenn
Looks like the result of Roadrunner & Coyote getting involved.   ;D
Quote from: zenrat on February 06, 2018, 02:15:34 AM
NEW! From ACME - the Panzer Pulverizer!!
It Slices - It Dices - It Makes A Complete Mess Of The Other Fella's Gear!!!
Buy now, stocks are limited* - Operators are Standing By!
Order NOW!! and receive a Free set of Steak Knives!
*To 100, 000 units this week...
Glenn
As you can now see, the hull width of both tanks is the same.
Beep! Beep!
Glenn
C-130 gunship at US airshow....gear down, doing a low pass.
Big Warplanes series.
Scale 1/144
Glenn
Glenn
Now, this is the Jagdpanther from the rear.....as I thought it would look. But looking at the movie photo of the vehicle from the rear, I realised it had been shortened. After adding the T-55 engine covers I could see how much had to be removed......
Glenn
No aircraft model yet in 2018? Will you make some this year? :-\ ;)
Glenn
Yeah Tophe,.......plenty in the pipeline!
Glenn
 ;) Good! (for me, sorry for the tanks lovers)... :-\
Glenn
This is what the model looks like untouched, before Photoshop.
Glenn
Quote from: Glenn on February 20, 2018, 06:29:11 PM
Scale 1/144
Glenn
She means business!!!  :mellow: :mellow:
It was so perfect I was very sure this was a Real airshow not a model of yours... Congratulations! :bow:
That post photoshop image could pass for real  :thumbsup:
