Glenn's Current Modeling Projects
Started by Glenn, September 02, 2008, 12:58:57 AM
Glenn
OK, back with the JagdPanther, as you can see...I've used the T-55 for a couple of things.
1. Making a new front panel to get the right length and width, and
2. cutting the engine cooling system off the kit, and replacing it with the T-55 engine panel.
Then removing the sides of the rear to the same angle to the JagdPanther and wamo! it looks like a bought one.
At present, the tracks are on, and I've scored the Zimmeret (?) to all sides.......the tracks, now, that's a story in itself!
Glenn
Glenn
A better view of the side, but after this shot was taken, I cut down the side parallel to the engine cover as thet's how it's done on the real one.
Glenn
Glenn
As I now have two T-34/76, I decided to use one for something else. This is going to be a river barge with a T-34 body and turret mounted. The tank will be mounted low, with only the turret visible....well, that's the plan?
Glenn
Quote from: TheChronicOne on April 06, 2018, 05:43:50 AM
Ahhhh yes, an Ironclad.  ;D ;D ;D ;D
Yup I can see that coming in handy as an improvised riverine type vessel  :thumbsup:
Glenn
After seeing it at this stage, it ewally needs to be lower to the waterline.....so, it will be cut down by about 10~15mm.
Glenn
I would have thought 5mm to 10mm personally Glenn
I'd have cut off the track guards & set the tank down into a well in the boat, with the overhanging sides of the hull sitting on the deck.
Glenn
Like you said, the sides on the deck. Saw a Soviet riverboat on the web, long and narrow with a set of  rockets behind the bridge and the turret of a T-34/76 in front...one mean machine!
Glenn
Glenn
Vickers Wellington RAF Coastal Command prepares for another adventure over the Irish Atlantic coast.
Big Warplanes : 1/144 scale.
Glenn
I am happy... :thumbsup: Dear Glenn comes back to aviation, a little... (feel free to do something else, of course, even if I will be less enthusiastic, as far as I am concerned)... ;)
Nice!! Always a fan of that paint scheme.
bodgybuilder
Very professional, looks great.
Matthew
Quote from: Glenn on April 13, 2018, 08:33:42 PM
Glenn
Can we bodge it?.......Uh.......Yeah, I think so
