avatar_david sMiGielski
Baltic What-ifs
Started by david sMiGielski, September 06, 2008, 08:10:55 AM
david sMiGielski
I need some advice. I recently found a source for Latvian and Estonian markings and I'm planning on doing a series of near future Baltic builds. My initial instinct was Latvian F-16A MLU's, Lithuanian F-16Cs, and Estonian Gripens.
But here's where I'm torn. Vipers and Gripens seems so no duh. I'd like to build something I don't already have a ton of in my stash. For example, would old Viggens or Tornado F.3s still have enough life in them to be of use to a small, not too wealthy Baltic nation?
I'd be interested in any other ideas people might have too.
Thanks.
-David
Ed S
Well, there are still countries flying F-4 Phantoms, A-7 Corsairs, Mig 21's and Mirage III's, all basically 60's jets.  So  I don't see any reason that Viggens, Tornados, Jaguars, Mirage F-1's or other 70's/80's jets couldn't be in active service for a lot more years.
Ed
Tornado is definately not a problem, it's of a similar vintage to the F-16 & the RAF will soon be off-loading a fair few.  Jaguar is a little older & the RAF just sold off a lot, mostly to museums & such but they would have made a hefty addition to smaller less wealthy air forces.  Viggen again was recentley off-loaded by Sweden & it's not too much of a stretch to see that girl uprgraded a bit & a sweet deal done with the Swedes.
The only thing I'd say against those particular aircraft is they are a little 'unfashionable', especially the Viggen & Tonka as they are both outside of current 'thinking'.  Doesn't mean it couldn't happen though.  It's not unknown for some manufacturers to produce upgrades for ageing aircraft and offer them as 'new' aircraft to nations not able to afford something bright & shiny.
Another option is if you do want to go for something 'bright & shiny' is that smaller air forces occassionaly acquire a small number of modern aircraft to bolster larger forces of older or less capable aircraft.  So an air force made up by a bulk of F-16's with say half a dozen Typhoons or Rafales might not be too much of a stretch.
Although both nations are now NATO members, ex-soviet equipment isn't completley out of the question, there have been several recent MiG-29 & Su-27 upgrades that might be very attractive.
And to sum up, any frontline aircraft in the same camo as the blue/greys Estonian L-39 would be v.:ph34r:!!!
Perhaps something in the class of the Hawk100 or AMX might be more appropriate?
Outlandish, but maybe with a new cold war brewing post Georgia, the USAF transfers some of its older F-15s or even A-10s to these countries to bolster the "front line".
Shasper
From a practical slant, maintenance needs would be a big determiner in selecting a particular type, especially if it's an older generation A/C, as well as making sure to have a reliable source of replacement parts.
shas b)
- Bud S.
Shasper is right about maintenance , i would think the F-5 would fit the bill, but then again-- Its What-If! There are plenty of smaller nations armed to the teeth with the latest and greatest. Its usually because they have valuable natural resources but hey maybe Latvia strikes oil?
If we want to go for practicality, the only one of the modern western fighters would be the Gripen really.
Maverick
Of course if you needed justification, you could always allege that your country was being taken over by (insert stereotype here). :wacko:  That should guarantee bright & shinys by the boatload.
Mav
Shasper
Unless it's Godzilla, then you're better off with an ice gun ;)
Shas 8)
- Bud S.
Well the primary mission in each case would be air defence against a hoarde of MiG-29s and Su-27s at short range, so anything less modern and agile than an F-16 would be in trouble. Re-fitted Viggens might just pass muster, but I'd hesitate to put Tornado F.3s into that scenario. If you want to be different, how about Mirage 2000s? Maybe in the whiffiverse the Rafale programme ran a bit quicker, thus allowing the Armee de l'Air to offload 2nd hand Mirage 2000s early in the 21st century......
Another possibility would be for some single and dual seat L-159 ALCAs:
Archangel
its a good thing that when you go into Whiffing kits anything is possible. Sweden is in real life crushing as many of it's Viggens as it can that are not going to museums and gate guarding.
AeroplaneDriver
That's a nice looking L39!
The Tornado F.3 might not be a viable option for a small Baltic country.  Not only would the MX be an issue as Shas pointed out, but it is a long-range missile carrier, designed to work as part of an integrated system with AEW and Fighter Controllers directing it to BVR kills.  The best future use of the F.3 would be as an RAF SEAD platform, but that will likely never happen.
As the "Deal of the Century" F-16 users transition to Typhoons, Grippens, and the like over the next few years I imagine quite a few F-16s may come avialable.  They are still highly capable mulit-role fighters that might fit the bill for this whif scenario (as long as they get painted something other than gray!!).   ;D
Geoff
Upgraded Mig-29's?
But I agree the early F-16's second hand are probably the most likley if only due to cost and availability.
