avatar_Howard of Effingham
aerial UAV control a/c - any daft ideas?
Started by Howard of Effingham, September 30, 2008, 01:35:57 AM
Howard of Effingham
i have been idly wondering in the last few days as to what a/c could be used as
an airborne UAV control a/c. could for example the USAF use a DC-135? or
would a DP-3 work for the USN, rather than use ground control stations often
very remote from the battlefield or to help supplement them.
really its an excuse for a large model over the winter,  :wacko: as i am also
wondering what the RAF/FAA/RM would find useful in this role also. perhaps a
modified vulcan would do the trick. i am sure that some of the 1980's era drones
could be attached under the wings of one.... or is this cruelty to avros?  :thumbsup:
suggestions please.
trevor
[who is also contemplating a HP80 drone controller too, btw!]
Keeper of George the Cat.
Why limit yourself:
DC-5B
DC-747 (well probably DCE-4B or something like that)
DCA380
Mornin' Trev
Depends upon whether you're looking to build a Controller/Launcher or simply a Controller. Controller/Launcher would need to be big, but relatively cheap to operate - I think the V-Bombers would be too 'complex' however if your time-frame was the mid to late eighties, I'd be thinking of opening one of those FROG/Revell Shackletons......  :o
A later time-frame would probably involve something from the 'civil' side - on lease from 'Targets are Us' or whatever that outfit who fly the Falcon 50's out of Hurn are calling themselves these days.
The Nimrod AEWs were scrapped.
If you want to air-launch the UAV, then depending on the size of the UAV you may need a high-winged aircraft. Maybe a BAe 146-300 with CFM-56 on the inboard pylon, and drones on the outboard pylons...
There was one AEW.3 that was at RAF Finningley until it closed in 1993, used as an instructional airframe.  The cockpit section still exists, minus the radome.  I think it went to Warton for some time & now is at Solway Aviation Museum in Carlisle.  The rest of the arframe was rendered for spares & scrapped.
http://www.solway-aviation-museum.co.uk/Nimrod.htm
Trev, there was that Vulcan that was proposed to carry three nuked-up Gnats.  Turn those into unpiloted drones & you get rid of a lot of the problems associated with that concept.  Herc's could be possible drone control aircraft too, Belfasts earlier on?
Quote from: Mossie on September 30, 2008, 05:16:08 AM
Belfast Drone Carrier/Controller..... now that just has to be done ('C' Flight 100 Sqn, Llanbedr Detachment) ...... WOOKS we're looking at you ! :bow:
Rafael
Quote from: pyro-manic on September 30, 2008, 11:58:54 AM
What about a B-52?
Pyro might be right, even a B-1 wouldn't be stretching it too far, according to what I read in Dale Brown's novels......
or a DC-10 or BAC-111 :wub:
Rafa
1/72 Scale Maniac
YOU - ME- EVERYONE.
WE MAY THINK DIFFERENTLY
BUT WE CAN LIVE TOGETHER
For the RAF, what about a modified Canberra? Fuselage stretch behind the cockpit for a few drone operators, bomb bay full of fuel for extra-long range, tip tanks, etc. - even a couple of stand-off missiles uner the wings for attacking anything juicy the drones find?
How about a B-1B?  There was mention in one of Dale Brown's novels (forget which) about a B-1 that could insert & recover small UCAV's that could be controlled from across the globe.
You could do a similar thing with a Backfire, or maybe an excuse to buy the Trumpy Blackjack???  :party: :party: :party:
Other options on the same lines Trev, the XB-70 if you can find the AMT kit & feeling masochistic, or the A-Model Sukhoi T-4 if your feeling flush???
Quote from: GTX on September 30, 2008, 02:11:32 AM
Why limit yourself:
DC-5B
DCA380
Here ya go, the DC-5 and DC-A380 ;D
;D
upnorth
How about a Victor?
If they had ground clearance for the drogue pods under the wingtips, then certainly UAVs could get slung under there, you could have a couple more in the weapons bay. You could use the old Matchbox Victor with minimal mods. Just remove all the IFR gear (save its own probe) and engineer a bomb bay of some sort back into her.
The ECM "carrots" are already in the kit and would look right at home on a drone control bird. Certainly there must be room in that big nose for some mission specialised gear too, no?
My Blogs:
Shasper
You could do it with a modded Tonka, right now the Army's looking at using the Longbows as a control platform for some of their UAV projects, so it's feasible . . . to a degree.
Shas 8)
- Bud S.
elmayerle
Perhaps a two-seat DF-20B?  Or if you needed two UAV controllers, a three-seat F-20 utilizing a forward fuselage that crosses F-5B/T-38 and F-5F bits and has solely a weather radar in the nose (though i could see a RF-5A nose getting modified with modern sensors as a guidance supplement).
--Jane Wagner and Lily Tomlin
