avatar_GTX
Kiwi Resins CA-15
Started by GTX, October 24, 2008, 01:14:06 PM
Does anyone know if this is available?  I see one is being built on HS.
Don't worry - found out from the man himself.
1/48 CA-15 is available!!!
Cost is $99US plus post.
Here you go:
Over on HS, Dave Lochead  of  KiwiResins is asking for input on colour scheme for a build he is doing of one using reject parts.  Jis possibles at this stage are:
Prototype?
South African AF in Korea?
RAAF as above?
Foliage green with white leading edges and tail?
Grey Nurse?
RNZAF?
RAF in Suez markings?
greg
Cheers Greg, looks really nice in the pic that shows (top four are the dreaded X )  I've got the 1/72 Czech Master Resin kit which is quite good, I hadn't realized that there was a 1/48 one on the market.  I was doing some dry fitting with it when I first got it and thought it would look neat with a five blade prop, I found that the Sea Fury prop & spinner fits real well on it.
elmayerle
I'd always figured that there'd be a production version with a 5-bladed prop and a high-speed/racing version with 3-bladed contraprops.
Korean war or SEAC markings from an extended WW II would be quite plausible markings for Dave Lochead's build.
--Jane Wagner and Lily Tomlin
I did a comparison of it with the Martin Baker MB5, they're about the same size, so contra-props would definitely be on the cards (fitted with some Shackleton props.)
Quote from: kitnut617 on October 24, 2008, 07:12:17 PM
Can you see them now?
Yes thanks Greg, looks really nice
elmayerle
Quote from: kitnut617 on October 25, 2008, 09:19:38 AM
I can see them going with either a 5-bladed prop or contraprops for production, though I'd think initial production would likely use the five-bladed prop because it would work with existing engines while the contraprops would require a different engine gear box and other modifications.
I think I read that it was originally to be powered by an R-2800, but as usual I can't find where I read that to verify.  It's certainly big enough that a large radial wouldn't look out of place. Maybe an R-3350 or R-3460 ----
elmayerle
Quote from: kitnut617 on October 27, 2008, 07:51:48 AM
Yep, it certainly was.  The Australian Aviation book on aircraft in Australian Service that includes it has good covereage of the design evolution from a developed Boomerang with a R2800 to what was finally produced.  I seem to remember that, at one point about 10 years ago, someone did a limited-production kit of the R2800-powered version.  If they'd kept the radial, I could see a production version with a Centaurus and a 5-bladed prop off the Sea Fury.
Quote from: elmayerle on October 27, 2008, 10:09:19 AM
There you go ----  :thumbsup:
tat2
Here are a few profiles of the radial Ca-15's.
Doesn't those canopies look a little Fw.190ish
