avatar_Spey_Phantom
Focke-Wulf FW-226 Flitzer
Started by Spey_Phantom, November 28, 2008, 04:57:43 AM
beowulf
ive been thinking about navalising a flitzter..........after all, it was supposedly to be of comparable performance to the me 262 but in a smaller packaage.....be easier to move about on that aircraft carrier they would have had in '47  ;D
allergic to aircraft in grey!
Barry Krell
Quote from: Mossie on January 12, 2010, 04:43:59 AM
A pure jet version with a cannon in the nose & revised nose wheel layout
No, it's a turboprop - note the extension shaft from the engine.  The thing in front of the engine cannon is the gearbox for the prop.
CMK did a kit of it and it was reboxed by Airmodel in 1994 - I've one in the stash somewhere.  You can pick them up quite cheaply these days.  Needs a fair bit of detailing though.
If you're doing the Revell Flitzer, you may want to think about replacing the wheels as they're horrible.
Aston Martin  - Power, Beauty, Soul.
I see it now, ta!  I had wondered what the 'funnel' things were in the nose, it's obvious now it's a truncrated prop.
I'm very much thinking of building the Revell kit pretty much right away, I need something simple to get me back into the swing of things.  I see what you mean about the wheels, they're too thick for the wing, but I don't think I've got owt to replace them with.  I've a set of Aeroclub wheels that I think were for an F-84, they might do but they've got a large hub that'll need removing, I guess that side will be going to the struts!
Someone should do one in RN FAA colours.
Quote from: GTX on January 13, 2010, 01:09:25 AM
Oh, I'm thinking about FAA alright, but not in the way you are!?!?! ;D
Quote from: Mossie on January 13, 2010, 06:57:33 AM
How do you know??? ;D
Barry Krell
Use Fw 190 wheels, they're about the right size and look 'right'
You couldn't use the Revell Flitzer to do that version - the fuselage is way too slim for that engine. IIRC it's a DB-021 based on the HeS 011 which was a centrifugal type engine and really chunky - see the engine in the Huma Me P.1101 (the Dragon kit has a jumo rather than the Heinkel engine around which it was designed)
The CMK/Airmodel kit looks closer to the second drawing Mossie posted as it has the raised cockpit to clear the prop shaft.
I've noticed with the Flitzer that if you want to do anything with, that triangular cross section pretty much prevents it.  In fact, most FW fighter designs are like this due to that classic canopy shape.
I'll see if I can pick up a cheap butcher bird, although I might be making a Hannants purchase soon in which case I might put a set on the order.
Barry Krell
Just ask about and see if anyone has a spare set of Fw 190 wheels.
That would be the easisest bet!
BUMP:
i have a couple of Flitzers left in the stash, and im thinking of building upgraded luft'46 versions out of them.
i was thinking of fitting them with an underbelly 20mm cannon pod and 2 underwing Ruhrstahl X-4 Missiles.
perhaps i can also build an early version in a Swiss version, perhaps with the same livery of the Bf109?
i was thinking the 2-tone grey livery with the red surfaces and white crosses  :mellow:
That would certainly look good !
dumaniac
I think the Swiss colours look good on any aircraft
