avatar_frank2056
Special Operations sub
Started by frank2056, November 29, 2008, 04:49:18 PM
frank2056
While going through my stash of started kits, weeding out the ones I'll never finish, I came across the Dragon/DML 1/700 kit of the HMS Trafalgar vs. Oscar. The kit parts were very nicely detailed, but the sub hull fit was just awful, and this is why I put the kit away some 10+ years ago.
This time, I took the HMS Trafalgar and through the magic of scaleorama, turned it into a 1/350 covert, special operations sub, designed to launch cruise missiles, recon UAVs or whatever special ultra secret stuff that would require a small, stealthy sub.
First, I moved the sail back about 5mm and added the dual chamber payload pod (The missile tubes from a 1/400 scale Tarantul kit) behind the sail. I tilted it up slightly.
I modified the tail fins as well. I lost one of the fins, so a good excuse was to say that since the large payload pod would affect the flow of water over the dorsal fin, a smaller dorsal fin and two smaller vertical fins on the elevators would do the job.
I also modified the shape of the nose and covered up the four torpedo tubes. I painted the sub in a dark gray. As an experiment, I placed small pieces of 3M blue tape at random over the hull, then repainted everything with a darker shade.
I tried some Createx transparent gray acrylic paint for the first time, and it was a disaster, leaving a pebbly finish on everything. I managed to remove most of it without damaging the underlying acrylic paint, mainly by running a Scotchbrite pad over the surface until it was smooth again. Then I laid down several more layers of the darker gray paint.  I removed the tape, which left an edge due to all the extra paint, so the sub got another Scotchbrite treatment. I misted the sub with a final layer of the lighter gray paint and did some minor weathering.
The subtle paneling in this picture is what I was after, and it's closer to what the model looks like in non-flash lighting.
The unpainted 1/350 scale figure is just there for scale. I'm not sure that the scaleorama effect worked, and I probably should have been more careful lining up the tape bits, but there it is. Total time was just 2 - 3 hours last weekend (plus whatever time I spent assembling and sanding the poorly fitting hull back 10 years ago) and another hour last night.
Frank
Cute!
I guess the guy could REALLY hold his breath!  :wacko:
Interesting idea about using tape to mask off sections. Probably only needed to be there for one coat, then peeled off so there wasn't such an edge. A couple of overcoats of clear or color coats would probably have blended it in OK.
frank2056
Quote from: sequoiaranger on November 29, 2008, 05:09:28 PM
If I'd not used the Createx paint and just finished it with a light misting of the original light gray, that would have been the effect - only a slight paneling, with no steps.
OTOH, this is a good trick if you need to make a depression or slight indentation on an otherwise featureless surface - tape off the pattern, then spray several layers of primer. Remove the tape when try and give the surface a light sanding to remove the edge.
Jeffry Fontaine
Hi Frank,
You are certainly headed in the right direction with the scale-o-rama theme with that submarine.  I had similar ideas but would have gone for a larger 1/72nd or 1/35th scale to make it that much smaller in size.  Now if you get the 1/350th scale DML/Dragon Typhoon you could try to scale-o-rama that into 1/35th scale swimmer delivery vehicle.  :)
Rafael
Frank, this is a marvelous model!!! :wub: :wub: :wub:
The concept and the idea make me remember the new French SMX-23 special-ops and littoral submarine
Rafa
1/72 Scale Maniac
YOU - ME- EVERYONE.
WE MAY THINK DIFFERENTLY
BUT WE CAN LIVE TOGETHER
frank2056
#5
Quote from: Rafael on November 29, 2008, 05:37:30 PM
FThe concept and the idea make me remember the new French SMX-23 special-ops and littoral submarine
Rafa, I hadn't heard of the SMX-23 until now. It looks like an interesting concept.
Jeff - I have the hull, but not the conning tower, of the Oscar that went with the Trafalgar. Maybe I should throw it in with the other kraptacular kits.
Hman
 :wub: :thumbsup: :wub:
Perhaps there is a Group Build in this - X Boats (Special Operations Subs)?
I thought of building one for a wargame - now there is no excuse!
"Lusaka Tower, this is Green Leader..."
Joe C-P
This came out well! An interesting adaptation of the original model.
That's one wicked Special Ops sub there Frank! I really like the launch tubes behind the sail!
:thumbsup: :thumbsup:
