avatar_Spey_Phantom
My Stash just grew again (2009)
Started by Spey_Phantom, January 01, 2009, 02:44:31 AM
Quote from: chrisonord on February 16, 2009, 05:54:26 PM
well, it won't float because of all the filler you will have to motherload it with.
Have you done an Amodel kit before? if not, get a stock of happy pills in and remove all sharp objects.
no...really!!
Yep - the Migina 1 I did was based on an Amodel MiG-9 and yes, grafting the front end of a G.91 onto it was the easy part.... :banghead:
no...really!!
Jeez, tell me about it.  I'm building their An-32 at the minute - its only the plastic thats holding the filler together :(
Radish
Some balsa square-sectioned strips/rods for WW1 type floats/pontoons for Camels, Fokkers, etc.. Different sizes for 1/72nd and 1/48th too.
Italeri 1/72nd JS-2 and Teutonic Knights for a comic-suggested idea :drink:
Mike Wren
Airfix 1/48 TSR2 to be scale-o-rama'd into a 1/72 big bomber
Revell 1/72 Hunter FGA9 & Tornado GR1 for I know not what...
Howard of Effingham
Quote from: Mike Wren on February 18, 2009, 05:21:41 AM
do the  :tornado: in french or swedish markings mike!
for myself a polar lights batplane. not sure what scale it is supposed to be but its getting
9 sqn RAF markings,  ;D
Keeper of George the Cat.
Just back from the Huddersfield Show and purchases made at the show and in the environs of West Yorks were -
Eduard 1/48 Spitfire F22/24
Eduard 1/48 Spitfire LF Vc
Eduard Nuieport 17 in Imperial Russian markings - only bought this because of the topless mermaid in the markings  :thumbsup:
All the above will be real world
1/72 Silver Cloud Avro 720 and Hunter P.1083 conversion
1/72 Fujimi Ju 87 B/R
1/72 Hasegawa Mustang III mit Malcolm Hood
Vitrix 28mm hard plastic British "Waterloo" Centre Company figures. Wanted to see what the detail on these was like - good
Radish
So 28mm figures = what in proper scales?
Aircav
Sir Sydney Camm
Vertical Airscrew SIG Leader
Steel Penguin
28mm some ware between 1:48 and 1:60, some companys pin at 1:55 ( bolt action amd chieftain), outhers may vary, and scale creep ( figures, from the same company, in the same line may slowly grow or shrink to an extent, { ill use games workshops teminators here, the new plastic ones are around 5mm taller then the old lead ones, despite being for the same user.})
with a large companys figs 1:35 scale kits do not look massivly out of place, { again 1:35 scale m113 apcs have been used with GW orks or space marines}  or you get to use then "scale o rama`d"  by using say a 1:35 scale Challinger tank with 28mm crew to give a "super-heavy" tank like the shadowsword is supposed to be.
some people find it very annoying, outhers like the effect you can get. take 3 differnt companys late world war 2 ranges and mix, as long as the painting is the same, it gives the effect of differant hight troops in the same unit.  It also generaly means that you can finish an army as a lot of manufactures dont produce every single option that you may want / need,.
Radish
Finally located a 1/72nd Hobbycraft CF-100 after hunting high and low. Toad snapped most of them up just to drive up the price, he's melting down 3 per evening. It will be given the U2 treatment.
rallymodeller
Courtesy of the generous services of Aircav, I now have a flying-type-guy for my RW 1/32 CF-104. He started as an F-16 pilot (from the Academy F-16CG/CJ) but he is on his way to being backdated to a 1980s Starfighter pilot. And no, this does NOT mean I'm suspending him under a parachute.
--Jeremy
frank2056
From Sprue Bros.:
1/700 SS Jeremiah O'Brien Liberty ship (new in this scale). This will be built as the O'Brien; I've been on that ship and have plenty of reference pics.
1/700 JCC/LCC-20 USS Mount Whitney in its 2004 fit. This will be whiffed somehow.
1/35 scale workable links for the Trumpeter M1A1/A2 tank kit.
KiwiZac
A coupla Italeri 1:72 heliochopters: OH-6A and RAH-66. Both to be whiffed......to differing extremes......... :blink:
Zac in NZ
https://linktr.ee/zacyates
Aircav
Called in at Chestermoor and then the Railway shop in Stanley and picked up some more Wills stuff,
Semi-detatched shops
Windows & doors
Arched brick work
Pavements
all in 00 as well as some Preiser Ducks, swans and geese in 1/87 plus a Hornby Tractor  ;D
Sir Sydney Camm
