avatar_Spey_Phantom
My Stash just grew again (2009)
Started by Spey_Phantom, January 01, 2009, 02:44:31 AM
Pretty excited to see some new arrivals at my LHS---managed to pick up Trumpeter's 1:32 EE Lightning, the new Monogram 1:48 B-58 Hustler and the re-issued Monogram Hind helo in 1:48.
Daryl J.
#211
HC P-59B for a SEA Scheme
CA Derek Pennington Special D-H Venom for the UAV series
CA Sea Venom with hopes to add sharp points to several areas.
Fine Molds Porco Rosso Savoia S.21 pre-shootdown.
Fine Molds Porco Rosso Curtiss R3C-0
All in 1/48.
Quote from: Radish on February 19, 2009, 09:50:27 AM
So 28mm figures = what in proper scales?
They are wargames figs Rad so scales don't really come into it as they "represent" a group of troops (actual number varies dependent on the rules you use and the ground scale said rules use) Most 25mm figures are nearer 28mm and some get to 30mm, most 15mm are nearer 18mm and some go to 20mm. Again most figures are measured from foot to eye, therefore the stated size is not strictly the height of the figure. Means you cannot easily match different manufacturers figures in the same army  :banghead: Marketing ploy ????? Still they are very good with loads of options as to how they are built up and posed - different heads, arms etc. Looking forward to the French stuff.
Whilst in MZ got the Italeri 1/35 CA L6/40 - a bit overpriced, but it does have some etch and one of their nice detail books.
Dork the kit slayer
At£9.99 for the whole boxed set,I thought this was a bargain. Picked up locally at a place called "the Range"
Quote from: rallymodeller on February 19, 2009, 06:08:26 PM
Courtesy of the generous services of Aircav, I now have a flying-type-guy for my RW 1/32 CF-104. He started as an F-16 pilot (from the Academy F-16CG/CJ) but he is on his way to being backdated to a 1980s Starfighter pilot. And no, this does NOT mean I'm suspending him under a parachute.
Ah, going straight for the wings and harp then?  :wacko:
Radish
At the Crewe Show today where I just dropped in for an hour or so.....
1/35th Trumpeter LAV-150 with 90mm gun :wub:
1/48th Pegasus Hobbies V-2
1/72nd Revell Fokker D.VII...think "Biggles"
1/72nd Revell Junkers F-13 (wheels and floats)
1/72nd Italeri Ju-88...for the Biggles build
1/72nd Italeri Hawk 100
Some plastic square-sectioned rod for WW1 floats/pontoons. :tank:
came in the mail today:
-my missing clear parts for my Airfix Blenheim bomber (excelent customer service  :thumbsup:)
-my decal paper supply for 2009/2010 (4 sheets clear and 2 sheets white paper, A4 size)
On Friday, I picked up an Italeri SU-34 and F-19 from MartG on this here establishment, F-19 looks like a good contender for UCAVing.
Yesterday after seeing Weavers post, went to Hobbycraft and got their last Revell Mig-31 for £7.49. Which is half what my LMS are selling them for.
From Crewe where we displayed as the Cold War SIG :-
1/72  Dragon Su-24 Fencer D
1/72  Italeri Su-32/34 Strike Flanker
1/72  Hobby Yak-38 Forger - Original tskuda kit of the Forger as used by Revell but in a normal grey plastic
Plus tools and paints etc
G
KiwiZac
Zac in NZ
https://linktr.ee/zacyates
Mig 31 Foxhound
Lancaster "Dam Busters"
CF-18A Hornet
All 1:72 by Revell, from the sale at Hobbycraft. The first two were £7.50 (half price), and the Bug was 20% off. Not bad at all! Also picked up a couple of pots of Citadel paint.
KiwiZac
MiniHobbyModels 1:144 F-111E Aardvark
Zac in NZ
Piggybacking off the 'Cheap Kits' thread elsewhere I dropped into my local Hobbycraft (Cribbs Causeway, Bristol) and picked up the newer Revell Mig-31 Foxhound, and the new Italeri Harrier GR3 'Falkland', as well some paint and glue and stuff.
Hobbycraft continue to surprise with their increasing range of 'serious' plastic modelling stuff. They even have large stocks of Evergreen styrene, not that I'd buy their plain sheets, but the sections are excellent and almost unobtainable over the counter elsewhere.
The GR3 looks good, with lots of stores and three decal options, one of the 'Atlantic Conveyor' aircraft, one of the other GR3s that flew direct to the Task Force from Ascension and one in the white camo overpaint scheme for exercises in Norway. As you'd expect, much of it is from their SHAR 1 kit, just the nose and stores on a separate sprue.
Howard of Effingham
RoG 1/72 EC145 'research pilsen' livery
[and if anyone can enlighten me on what the mathematical equations are on the decal sheet
i'd be very glad........ ]
Keeper of George the Cat.
