avatar_Daryl J.
De Havilland Sea Vixen
Started by Daryl J., January 01, 2009, 10:24:10 AM
For whiffing purposes, the old Frog kit is more than adequate, although an Aeroclub bang seat and white metal u/c improves it no end.  It was one of the last ones Frog did and it's not that bad.
The High Planes one is still available, AFAIK.
Cyberhobby?  Affordable?  The Meteor is nigh on £30 and the engines are waaaaay oversized.  Expect the Vixen to be nearer £40 and some of the accuracy to be dubious.  Dragon always find a way to screw the pooch.
Forgotten the Hiplanes one.  Yes, it is still available.  Might consider that one.
Could be hard work - High Planes stuff is accurate but limited run and thus necessitates more clean up.  Their Sea Fury fought me every step of the way but was worth it in the end.  Probably easier for you to get over there and certainly cheaper.
Quote from: The Wooksta! on January 26, 2011, 03:20:13 AM
I've encountered Hiplanes before and while "challenging" might be the best word, they aren't impossible.  Their Vixen costs $Au45.00 = £28 isn't over the top but it is at the top end of reasonable IMO (but then perhaps I'm just a cheapskate?  :mellow: )
QuoteIf De Havilland had gone for a more daring approach, the Sea Vixen might have been the Sea Devil instead... But in the 1950s, no one was willing to develop forward-swept wing aircraft. Not that it has changed much, mind you...
[Source]
DarrenP2
some better Air ti Air weapons might be in order for a more international Vixen
Aim 4 Falcon
Aim 7 Sparrow
Aim 9 Sidewinders
Matra 530
matra 550 magic
all might be good options
Zero-Sen
Quote from: rickshaw on July 26, 2016, 08:49:34 PM
[Source]
I remember doing a Sea Witch as a whif version of Stephane's Sea Devil with tandem backward-swept wings and twin tails (ala Hawker P1214)
Here she is...
Quote from: Zero-Sen on February 13, 2018, 03:05:43 PM
Here she is...
Excellent!  :thumbsup:
That's almost doable in plastic too............
Gosh!! It's an X wing fighter!!  Shades of Star Wars.
I'm looking for another Sea Vixen now..............  ;)
Quote from: PR19_Kit on February 14, 2018, 08:36:01 AM
You and me both Kit ---   :mellow:
Quote from: kitnut617 on February 14, 2018, 05:59:31 PM
....me too, if it's at a reasonable price!
I've got a FROG one already, which was destined for another Whiff that I posted on here AGES ago, but never got any further with. But if I find I have another one there's no contest really.  ;D
[Later] There's a singular lack of Sea Vixen kits on eBay, unless you count the exorbitant Dragon kit. But there's LOADS of die cast ones, crazy.  :banghead:
I've a Revell boxing somewhere I won't use if you can hang on for a bit.
Quote from: The Wooksta! on February 15, 2018, 03:46:12 AM
You're on Lee, thanks so much.  :thumbsup:
