avatar_Ed S
Autogyro in Vietnam, the AV-3
Started by Ed S, January 17, 2009, 07:02:38 PM
Ed S
It's the return of the styrene junkyard.  Here is an old Airfix OV-10 that I started many years ago.  But it had some problems and got thrown into the junkbin. It's going to be combined with parts from an ERTL Hokum (yeah, that kit, the fictional two seater....) to make an attack Autogyro from Vietnam.
Ed
Lovin' the gyro concept Ed, a very underdone side of whiffery IMHO.  :thumbsup:
Cool concept! :thumbsup:
Will you use the coaxial rotors or bash the two rotor hubs to make a 6-bladed main rotor?  :wacko:
Ed S
It's Mar 1:  Let the bashing begin!  Here are the major parts after the first round of surgery.  The tail has been cut off the Hokum.  And the bulges on the side removed.  The OV-10 wings have been shortened.  The vertical tails have been reshaped.  The booms have been trimmed to fit higher on the wing instead of below it as on the Bronco.
Here are a couple shots with the main parts taped together to see how it's going to look.
Ed
Hey Ed, I could have used your wing off-cuts on my CV-10. Saved me hours of filing and sanding! :) :)
That's an amazing concept and well engineered too.
What are you doing about landing gear BTW? The Airfix OV-10 needs its main gear installed before you join the boom halves (daft idea...) but you're obviously going to use something else as the normal gear would be miles too tall.
Ed S
Quote from: PR19_Kit on March 01, 2009, 12:46:06 PM
This will still have to sit fairly high off the ground for the prop to clear.  I will use the kit L/G with some minor mods.
Ed
Ed S
Haven't updated this build in a while.  It's been sitting on the back burner while I worked on some other projects.  Most of the major assembly and PSR is now done.
Ed
Definitely going in the right direction!  :thumbsup: :bow:
Looks very fast, already.  Sounds like a clever idea for VN, too.  Looking forward to more (please!).   :cheers:
Ed S
I haven't updated in a few days, but it looks like I will finish for the 1 June deadline.  Here are some pics with a coat of paint on it.  And then with the decals.  I just need to add some details and weathering which I should finish today.
Ed
Damn that's looking good - Nice one ed!  :thumbsup:
Ed S
Unhappy with the Air Force's insistence that it could provide CAS with its fast mover jets and frustrated by the Air Force blocking all attempts to get their own organic light fixed wing a/c, the US Army realized by the early 1960's that the only solution was to find a rotary winged a/c that could preform the CAS mission.  Even with the newer turboshaft engines, the helicopter's performance wasn't satisfactory for the CAS mission.  As they explored alternatives, Bell-Cierva offered them an advanced autogyro that could meet their performance specs.  The result was the AV-3 Crow, the world's first turboprop driven autogyro.  With short fixed wings that could unload the rotor at high speed, the AV-3 was the fastest rotary winged a/c in the world and could achieve speeds in excess of 250kts.  With the capability of carrying up to 3000lb of ordnance plus two 20mm cannon in the nose, it was highly manuverable and had better range and loiter time than a helicopter for the same mission.  Althought not capable of a true hover, the Crow did have a clutch driven rotor that could be run up to speed by the engine, allowing extremely short take off runs.  Widely used by the US Army during the 60's and 70"s, the AV-3 were finally retired in 1981. The USMC and a number of foreign operators also found the AV-3 met their needs as well and it proved a major sales winner for Bell-Cierva. In addition to its role in CAS, the AV-3 was used for FAC, Artillery spotting, battlefield recce, and laison missions.
Some photos
Ed
frank2056
That looks great, Ed! Your builds always have that surprise reveal where the end results aren't what most people (at least me) expected.
