avatar_cthulhu77
ARH Tilt Hovercraft
Started by cthulhu77, January 29, 2009, 08:52:32 AM
That is incredibile already!!;D
Go! Greg! Go!  :cheers: Ya know I never use straws for drinking but maybe I should start saving the danged things!
Do you have this sort of thing all figured out before you begin or do you simply jump in and let the muse take over as you go?
Zeke
So, the medication looks like it's kicked in then?
Cool... :thumbsup:
Well, I am glad you all like it so much !
To answer your question, Sir Mouse, for the most part...it just occurs, often accidentally. In this case, I just grabbed an old kit, and started gluing on bits and pieces. I also save almost every bit of metal and plastic that we use around the house. The hinges for the birth control fans were from bic razors, the fan blades were cut out of some blister packaging from my new (yay!) firewire.
The drugs are working just fine, as well as the hot tub ! Now I just need to build a modeling bench to go on the tub...
Cool hurry up with the rest of it :wacko:
noxioux
That seriously rocks.  The steampunk approach is perfect! :wub:
Added on the pilot, test fitting on the waves:
That is too freakin cool. Are you going to post it on the Steampunk Forum :wub: :wub: :bow: :bow:
what an amzing build. Superb work Greg!
Thanks!
Did run with the parasol idea, and will be working on the second half of the water making video this afternoon:
Damn  :o that definitely goes in next years Whiffies :wub: :wub: :wub: :wub: :bow: :bow: :bow: :bow:
