Main Menu
Sharkit
Started by Green Dragon, March 01, 2009, 08:28:46 AM
Quote from: renax on March 14, 2013, 02:58:27 AM
kit page update:
http://www.sharkit.com/sharkit/emerson/emerson.htm
With four top quality metal barrels
That's awfully tempting: I bet you can adapt that nose to all sorts of other aircraft too..... :wub:
renax
Fun for some what if for sure !
renax
Instruction sheets of the fernbomber can be download here:
http://www.sharkit.com/sharkit/Ho-XVIII/HoXVIII.htm
Jeepers, that's a BIG aeroplane!  :o
renax
Is a six engines bomber, transatlantic...
wingspan is about 22 inches, 57 cm.
I am painting the boxart right now...
something like this:
http://renax-sharkit.blogspot.fr/2013/03/new-sharkit-horten-xviii.html
Quote from: NARSES2 on March 13, 2013, 08:44:56 AM
Thank you Tophe  :thumbsup: Something smilar was proposed for the Blackhawk nightfighter
And the F-89 Scorpion.  There was quite a fad at the time for such turrets.  Made the ammunition feeds quite complex.
Quote from: renax on March 15, 2013, 12:23:03 AM
You know the first thing that went through my mind when I saw that big greenhouse canopy was "Lancaster": wonder if you could pass it off as an intermediate step between the Lincoln and the Vulcan....... :wacko:
renax
#247
at this time germans had no means to make large curvy canopies or clear parts;
despite its construction the canopy is very streamlined;
Below is IAE38 one;
Quote from: rickshaw on March 15, 2013, 01:55:03 AM
I've been trying to work out the ammunition feed system myself
Quote from: NARSES2 on March 15, 2013, 08:16:23 AM
I don't think the feed is any different to other feeds for the .5".  Considering the 'whole' nose rotates, the ammo cans would too as IIRC they're set in between the two slots.
As Kitnut points out, the ammunition magazines are in between the guns but because of the large angle of movement, they had to be placed behind the actual guns and were connected by flexible feed chutes.  I've got a F-89 book around the place with some extensive pictures of that turret.  The nose is occupied by a radar which controls the guns.  I'd assume the same with this turret.   I can't see a fighter pilot being able to fly and aim the guns over such a broad range very easily.
Cheers gents. There just didn't seem much room for ammo to me.
renax
Madoc
Renaud & all,
Egads!  Will you look at the fire control gear for that thing?
http://www.sharkit.com/sharkit/emerson/X17A%20Installation.jpg
That thing looks about the size of not one - but TWO refrigerators stacked next to each other!  All this crammed into a single seat fighter?  Yikes!  Nowadays all that computing mechanism would fit into your shirt pocket.  Not sure about the servos but I find it hard to believe they'd be so bulky as this thing.
It's wonderful!
That is, so long as I wasn't the poor SOB charged with pulling maintenance on it!
Madoc
Renaud,
What are the differences with this Fernbomber versus the previous issuings of the kit you've done?
