Main Menu
avatar_r0t0rdr1ver
Bf-109M-2
Started by r0t0rdr1ver, March 28, 2009, 08:47:55 PM
r0t0rdr1ver
#15
Quote from: JayBee on March 29, 2009, 12:55:49 AM
The interupter gear for the cowling guns would have to be some fantastic bit of engineering.
The MG 151/20 was electrically cocked and used electrical ignition rather than a percussive firing pin.
In the wing-root installation used on the FW 190, the two MG 151/20  were synchronized to fire through
the propeller arc.
The 13mm MG 131 also used electrical ignition.
Jon
As I said above, its your model, however if it were me:
QuoteThe wheels are turning on the tricycle gear also...
I'd stick to taildragger to avoid it looking too similar to the Me-309. Besides, the nose will be fairly cramped as it is with the engine.
Re colour scheme, I'd probably go with something similar like the late war Ta-152s with simplified markings, e.g.:
QuoteGreg has been known to have a good idea or two
Hey cut that out, I'm in enough trouble!
Great so far!
Re camouflage, doesn't have to be German I suppose?  Israel operated the Avia S.199, but it was in a bland overall grey, how about the brown/blue camouflage worn on their Spits & Mustangs?
