F-104 with F-16 wings and tail
Started by tigercat2, April 28, 2009, 06:36:24 PM
tigercat2
In an attempt to make a "poor man's Lancer", I tried mating the wings, horizontal and vertical tail  from an Academy YF-16 to an F-104 (in 1/72 scale).  To date I have done three; the first '104 used was from Hasagawa, it is overall Grey; markings pirated from an F-101B. It is the 2nd in the line up, to the left of the TN ANG '104.  More to follow.
Wes W.
tigercat2
The next '104/F-16 combo used an ESCI F-104, and is in a white/orange scheme (one of the test birds).  Decals pirated from an F-100, '101 and '86.
Wes W.
tigercat2
The third and to date last '104/F-16 combo again used the ESCI '104; it is in NMF, white wings, and totally ficticious markings.  It is, after all, a What if World.  Here it is shown with the other two '104s.  I will try for clearer photos in the near future.
I plan to add several more to the fleet, as soon as I can get some additional 1/72 F-104s.
Wes W.
tigercat2
Here are a few more 104s, with a Lancer (courtesy of MCollazo) thrown into the mix.
Wes W.
Looking very sexy all loaded up like that.  Good job.   :thumbsup:
Forget what you may think you know about the Lancer project not proceeding to success.  The real reason was that they realized that removing a T-Tail from such a hot bird was...just...wrong!
tigercat2
I thought that the T-tail was the cause of problems, with both the F-104 and F-101.  I recall reading that the Air Force was very concerned about the pitch-up with the '101, and were considering a major mod to install a conventional tail until MacAir came up with a stick shaker.
Wes W.
Zeke
That makes a really interesting modification doesn't it?...it's almost a second glance kind of thing...looks right!... :thumbsup:
tigercat2
In doing the mod (which was extremely easy, BTW), I could not help but think what a good airplane that would be in real life.  With an F100 turbofan and F-16 wings, the '104 so modified should really be something; throw in F-16 avionics and it think it would have given the real F-16 a run for its money.
Too bad the USAF did not listen to Kelly Johnson; he was hardly ever wrong.
Wes W.
The Big Gimper
#8
I did not see this thread before I came up with this combination.
CF-104E which is an ECSI CF-104A with Hasegawa F-16D wings and if I can make it work, General Electric F110-GE-129 or Pratt & Whitney F100-PW-220/220E replacing the Orenda J79-OEL-7.
CF-104E-02
by Big Gimper, on Flickr
Work In Progress ::
Lots of stuff
Does it come with a red fuselage like that out if the box?
The Big Gimper
#10
Yes it is to my surprise. This boxing:
Work In Progress ::
Lots of stuff
A bit like the Revell Snark kit then, you need sunglasses just to build the model!  :o
There was also a Tiger Meet Starfighter from ESCI, and it came in bright yellow!
Looks like a very good upgrade! Could it be that the wings need some trim at the wing/fuselage intersection, so that the wing tip rails are parallel with the aircraft's longitudal axis?  :o
Curious about the looks with the F-16 fin (and a T-tail, I assume) - I really like the concept.
Makes me wonder if MiG-21 wings could be transplanted, too, for an alternative high speed version?
I've got some decals to do that red 104 Carl --
Jesse220
