avatar_TsrJoe
Luft'46 German Nuclear Weapons (WHIF)
Started by TsrJoe, May 06, 2009, 01:44:08 AM
sagallacci
Here is a sketch of the very early gun shape being dropped at Wendover, based on the photos in the Coster-Mullen "Atomic Bomb" book.
Presumably the device was to have a massive tamper in the nose and a long gun tube. The length might reflect a higher velocity gun, either to make sure a U235 weapon wouldn't pre-detonate and/or before it was clear that even at high velocity, a Pu weapon could not work due to pre-detonation.
TsrJoe
#62
cool thanks for posting the sketch 'sagallacci' definately a different configuration for sure, sortv like a stripped out 'Little Boy'
meanwhile, Antares 1/48 scale resin German weapons ...
TsrJoe
TsrJoe
iv made a 1/32 scale 'small uranium bomb' with 'saddle' based on the Georg/Shestakov artwork, just to be different iv a Hasegawa Fw.190F.8 which i'll mount it beneath as opposed to the Me.109 or Ju.87 usually depicted
cheers, Joe
TsrJoe
#65
TsrJoe
a generic schematic of a possible 'atom bomb' from a post war German publication ...
Jeffry Fontaine
Interesting fin arrangement on that conceptual drawing.
Quote from: Jeffry Fontaine on February 08, 2010, 05:42:37 PM
Indeed. Could it actually be a shroud over a parachute pack, i.e. it's designed to blow off alomst immediately after dropping?
sagallacci
Looks more like a WAG of the US Mk3/Fatman configuration and the tail is just bad art/simple drag plate.
TsrJoe
TsrJoe
TsrJoe
SA.4000 V3 radiological 'dirty' bomb at RAF. Museum storage facility Stafford
reference, 'Aeroplane' June 2006
quote, Curator Ewen Cameron ... 'one of Hitler's nuclear weapons. Not a fission weapon, but the original dirty bomb. It was designed to drop a mixture of radioactive isotopes and high explosive; the conventioinal explosion would scatter radioactive contamination over a wide area'
note the V3 and SA.4000 notations on the casings, applied by allied forces for identification
cheers Joe
TsrJoe
#74
cool nice 3d renders, an interesting bomb configuration too, different from the norm, is the Horten XVIIIb avaliable as a kit as yet ?
(i had started scratchbuilding one til i discovered the drawings i was using didnt match those shown on an original i later found...typical!)
many thanks, Joe
