avatar_Weaver
Yak-25/26/27/28 (the big twins)
Started by Weaver, June 12, 2009, 04:16:33 AM
As far as I can see there isn't a thread for these, but mods, if I'm wrong, please feel free to merge this thread.
So, what to do with the big twin-engined night-fighter/bomber/recce yaks then?
One thing I've always fancied is an advanced strike version, with the bomb-bay of the -28B, the tandem cockpit and solid nose of the -28P (but full of nav-attack avionics) and an Su-17-style outboard-pivot swing wing, the pivot points being above the engines.
I've talked about a swept wing Canberra today, so how about a straight wing Yak?  Could cause much head scratching when comparing it with an Il-28!
I think it might look good sticking the engines in the rear with intakes & horizontal tail on the fuselage.
OR, how about moving a Brewer's engines from the wing to either side of the tail, and then passing it off as a Tupolev predecessor of the Tu-22?
Ed S
Quote from: Mossie on June 12, 2009, 05:03:15 AM
There was a straight wing Yak-25.  The Yak-25RV "Mandrake".
Ed
Quote from: Ed S on June 12, 2009, 06:29:52 AM
Ed
Alright then, how about a SHORT, straight, very thin wing Yak-25 with a -28P nosecone: sort of Ruskie Bristol-188.
dy031101
Since I always like the idea of a classic plane with what-if avionics suite upgrades, I would think of an upgraded Yak-28P with R-40 and/or even R-27EM/ER/ET capabilities......
Quote from: Weaver on June 12, 2009, 06:33:34 AM
Put a rocket motor (or a cluster of them) in the tail, and we get a Ruskie Sud-Ouest Trident.
To-do list here
Jschmus
What about a Yak with turbofan engines and modern radar/avionics?
Captured Yaks in IDF-AF service?
The possibilities abound.
I just wish I had scarfed up those 1/100 Yaks I saw in a dollar store years ago.
I have been looking for more pics but the Yak-45 was designed for the PFI competition that later became the Mig-29 (I know it doesn't quite fit with the numbers shown in the thread title but it has that Yak look to it!)
Note Canards
Maybe start a build with an F-18 Fuselage?  :huh: Yakovlev sized up the design to try and get the contract for what became the Flanker and there is a pic of it out there but i can't seem to find it  :banghead:
... na, short trapezoidal wing (think early Avro 730) and stick engines on the wingtips ala the Myasischev M-50.
So Yak-25 + 188 + 730 + M-50 =  :party:
;D
Kit's First Rule of Whiffing says 'There's no aircraft in the world that can't be improved by fitting longer, straighter wings'  :lol:
So the answer is a Mandrake with even LONGER wings and the odd missile or two! I've been scrabbling about with something like this for a while, a Broplan Mandrake mated with an A-Model Yak 28 with wings from an U-2 or TR-1.
Can't make them all fit yet, but I'm working on it. It'll be a Yak-25PV, which translates to 'Perekhvatchik Vysotnyj (High altitude interceptor)' and it's NATO name will be Firedrake' (Firebar + Mandrake....... ;))
Quote from: joncarrfarrelly on June 12, 2009, 11:16:24 AM
;D
Good idea, although maybe base it on the -28 with it's high-mounted wing, which might let you put the underwing engines in M-50-style pods (assuming that the new aircraft's four engines are smaller than the old ones).
While digging out the kits for my Yak-25PV 'Firedrake' (see post #9 above) I found a kit for a Yak-25 Flashlight inside the A Model Yak-28 box, along with the Yak-28 kit! I can't recall buying it, but I suppose I must have at some time or another. There's only rudimentary instructions and no sign of who made it.
Anyone got any ideas on who the manufacturer might be?
frank2056
Kit,
That looks just like the Red Hurricane Yak-25. I have one at home that I've been working on - I'll compare the bits and the instructions. They also had a Tu-14 Bosun before they went out of business.
Frank
Frank,
Thanks for that, I can't imagine where I  got hold of one of them, I can't recall seeing Red Hurricane kits anywhere!  :o
That Tu-14 must be the only kit of that aircraft ever produced, I don't even think Airmodel did it, and they surely did produce some odd-ball machines.
I have a vacform Tu-14 - made by Sutcliffe Productions.
