avatar_JayBee
Photobucket test
Started by JayBee, June 28, 2009, 10:02:01 AM
OK guys this is partly a test to see if I can get photobucket to work for me as my upload folder is full.
So here goes.
http://i652.photobucket.com/albums/uu247/JBricknell/3X144.jpg
If this photo has appeared I will be mightily pleased.
It will also show three projects that have been underway for some time.
Like the one based on the Airfix Vickers Vanguard, has a hand written date of 7/1/99 ( thats British dates, ie 7th January 1999) and the VC-10 box had a page out of Flight international dated 1997!
If this test ahs worked then I will soon be able to start posting new stuiff again.
JimB
OK, can anyone suggest how I get an image from the Photobucket folder to show on the forum?
Under your pictures you will see 4 boxes. I just right click and copy the bottom one, IMG Code, and paste it into your message. You don't even need to use the 'Insert Image' option:
All you need to do for any image you have the link for is put it inside IMG tags, as follows:
[img]http://i652.photobucket.com/albums/uu247/JBricknell/3X144.jpg[/img]
that will give the following:
Thanks Alun.
Very much appreciated.
and thanks to the Rat as well.
Twiglets indeed.
I may be Scottish but give me Vegemite over Bovril, anytime!
JimB
Quote from: JayBee on June 28, 2009, 10:02:01 AM
Cool! Whats with that Trident? Looks like a BAC 1-11 nose :wub: Is the VC-10 shortened?
Those dates would be the standard for the entire world, except the US :thumbsup:
OK the three when finished will be:-
Vickers Nimrod MR2, which got finished three days ago, hence my need to get photobucket sorted out, so that I can post the pictures of it. That will be done in the next couple of days.
VC-10 AEW5, yes it has been shortened.
Trident K1, and it is the standard Trident nose.
JimB
