avatar_Radish
A-6 Intruder and EA-6 Prowler
Started by Radish, July 31, 2002, 01:01:22 PM
Hi folks,
I guess I should look at some of the posted links more often.  Look what I found on the beuliland.com site:
gooberliberation
Can't find any more camo'd intruders, but here's a profile of that green phantom and a SEA Vigilante
Not so much a whiff (its actually real world!), but still a different looking  Prowler:
Archangel
Take the body of an EA-6 and blank out the rear seat and paint it Gunship Grey and add a pair of F-404s. You could have the start of an alternate to the F-15E .
dy031101
#34
I recently heard that there is a Grumman Model 128U that is the ASW version of the A-6.
Hum...... folks, what is by your estimations the smallest carrier that could operate A-6?
(Midway class?  Essex class?  CATOBAR Ark Royal?  Clemenceau class?  Or...... even Colossus class?)
This question stems from the Wikipedia claim that the modernised Midway class is too small for S-3...... would those not wanting to be stuck with refurbished S-2 be able to appreciate the Grumman 128U?
(Of course, for AEW capability one still has to look at S-2 variations or Sea King with Searchwater......)
To-do list here
Jeffry Fontaine
#35
Something you do not see very often in the news or as a model.  Wally Civitico  has shared some images of his 1/48th scale KA-6D Intruder tanker on ARC that he has loaded up with fuel tanks and a scratch built hose and drogue unit mounted in the fuselage.
(image source: Wally Civitico/ARC)
MAD
For your Ferret / Wild Weasel Intruder - you should start with the two-seater EA-6B Intruder arrangement - the prelude to the EA-6B Prowler!
For this will already have the EW/ECM and RWR built into it!
M.A.D
Hard one to whiff, the A-6: the airframe's an odd shape to change and not really suitable for roles other than those it really did. :huh:
How about export customers? Given the small carriers available in the rest of the world, they'd probably be out as platforms, so we've talking about land-based strike, probably with a maritime bias:
Marineflieger/Italian with 4 x Kormorans
Japanese "anti-landing-craft" with 4 x ASM-1s
Portuguese/Spanish/Greek/Australian with 4 x Harpoons
RAF with Martels/Sea Eagles instead of the Buccaneer (hate the idea, but it's valid)
Australian 'nam version loaded with Brit 1000 pounders as a Canberra replacement
Quote from: joncarrfarrelly on March 01, 2010, 11:03:51 PM
Single-seater.
Yes I thought of that, and a tandem two-seater based on the Prowler, but they'd be awfully tricky to model, bearing it mind that cutting a tapered slice out of the A-6 fuselage would shorted the already stubby nose, angle the jet pipes outwards and change the wing sweep. One possibility might be to start with a Prowler, cut the slice, accept the shortened nose and them make that a single seater.... Another approach might be to substitute an entirely different centre and front fuselage, with the A-6 wings, engines and tail grafted onto it.
McGreig's got an interesting A-6 project underway, with VG wings and a pointy nose, although it preserves the side-by-side layout:
http://www.whatifmodelers.com/index.php/topic,19029.0.html
Quote from: Weaver on March 02, 2010, 12:55:32 AM
What tapered slice? The Design 128G-12 proposal in the drawing had the same fuselage width and wingspan as the A-6
and was slightly longer at 56' 6" compared to 54' 9" for the A-6. The proposal also incorporated a folding horizontal tail.
Attached is a quick and nasty overlay (of course the drawings don't line up exactly even though both are from the Putnam volume  :banghead: )
From the drawings it appears to me that it would be more a matter of building up and extending rather than removing.
Jon
Ah I see - I was assumed that any single-seater would be narrower. That overlay is very interesting: the single seat canopy is actually in front of the side-by-side one, which means you could fit a tandem cockpit if you wanted to.
What was the intended mission of the 128G-12 proposal?
dy031101
Quote from: Weaver on March 02, 2010, 07:50:23 PM
It competed against the A-7 Corsair, so I'd assume its mission to cover the same range......
To-do list here
Daryl J.
Hawker developed the Intruder with Grumman and I hear the Intruder IV was quite the machine for the British.
:cheers:,
Daryl J.
