avatar_Geoff
Old cracked decals
Started by Geoff, September 28, 2009, 12:30:50 PM
Geoff
I want to make a model which has been in the stash for a while now, a Bf-109C nightfighter which was based in Norway, a real world build.
When I looked it over prior to starting I noticed the decals had a few small cracks in them which make me think they will disintergrate when I put them into water.
Am I right in thinking I can paint these decals over with Kleer or a varnish to prevent them falling apart? I have not done this before so if anyone has any advice please help.
Thanks - Geoff.
Ed S
I've had some luck using a clear varnish such as Testors Gloss Coat sprayed over some old decals.  Other similar varnishes designed to cover homemade decals would probably work as well.  It wasn't 100% but I did salvage some of the decal sheet.  Future doesn't work for this.  At least the one time I tried it, it wouldn't come off the backing paper.
Ed
thedarkmaster
My own experiance is very similar to Ed's, with varnish you can salvage some if not most of the sheet, but be prepared to lose some bits.
I do have now some microscale liquid decal film, which claims to be able to " rescue " old decals but i haven't used it yet so cannot comment on it.
Geoff
Howard of Effingham
microscale liquid decal works reasonably well.
i have used it on an academy F-14A after some ancient microscale decals 'dissolved' into
zillions of small bits when i tried floating them off the sheet. there was a small amount of
silvering but not anything drastic.
suggest trying on a small unimportant decal from the spares box to help you get used to
using the stuff.
Keeper of George the Cat.
