Hypersonic Transport
Started by KJ_Lesnick, October 07, 2009, 10:59:02 AM
KJ_Lesnick
SSgt Baloo
QuoteI'm no rocket scientist, but I suspect that a spatular or rounded nose shape probably prevents the accumulation of too much heat in too small an area. Perhaps the aerodynamic advantages of a pointy front end are outweighed by thermodynamic issues as speed increases?
No the surface would be sharp.  The spatular term pertains to it's overhead look
SSgt Baloo
Quote from: KJ_Lesnick on October 23, 2009, 04:40:41 PM
SSgt Baloo
:unsure: I'm confused. That's what I was talking about (the "overhead look"). Even though the surface may look "pointy" in side view, the bluff overhead view affords more mass per unit of surface area than a conical point would afford. As I said, I'm no rocket scientist, so the reason I gave could quite easily be an incorrect one.
Not older than dirt but remembers when it was still under warranty.
KJ_Lesnick
SSgt Baloo,
I'm not sure how it's heat-distribution would fare over a pointed nose design honestly
KJ_Lesnick
The hypersonic side of the equation is complicated, but does anybody have any idea how a design like this would behave subsonically, particularly at takeoff speed?
I would imagine fairly well.  It looks to me like a lifting body style design.
KJ_Lesnick
Mossie,
QuoteI would imagine fairly well.  It looks to me like a lifting body style design.
Would you say you think it's takeoff and landing speeds would be good?
It's an ogival delta, I can't think of another aircraft that has had quite the same shape wing.  Concordes is similar being an ogee, if not quite the same.  Concorde tends to have a fairly high angle of attack when taking off & landing like many big deltas, but it's fairly forgiving IIRC as long as you're not maneuvering hard.  If that is a glazed nose, it shouldn't cause any problems visibility wise.
KJ_Lesnick
Mossie,
QuoteIt's an ogival delta, I can't think of another aircraft that has had quite the same shape wing.  Concordes is similar being an ogee, if not quite the same.  Concorde tends to have a fairly high angle of attack when taking off & landing like many big deltas, but it's fairly forgiving IIRC as long as you're not maneuvering hard.  If that is a glazed nose, it shouldn't cause any problems visibility wise.
So you'd speculate that it's takeoff speeds and landing speeds would be similar to the Concorde?
Quote from: KJ_Lesnick on October 31, 2009, 06:47:54 PM
Mossie,
The landing speed would be largely dependent upon the overall size and weight of the platform, not simply the shape of the wing.
KJ_Lesnick
GTX,
QuoteThe landing speed would be largely dependent upon the overall size and weight of the platform, not simply the shape of the wing.
Good point!
KJ_Lesnick
Okay, since I was thinking 300 passengers sounds good, I'm basically using the cabin widths of the McDonnell-Douglas Orient-Express as a start-off point.
Does anyone here know how wide a typical coach airline-seat is, how big the aisles are, or how tall the ceilings are typically?  I need to establish a baseline figure for the width of the cabin.
KJ Lesnick
Standard width is about 17in/43cm.
KJ_Lesnick
Mossie,
QuoteStandard width is about 17in/43cm.
Is that modern day or back in say 1980 to 1989?  Because this design is essentially based on the presumption that with technology of that era such a plane could be built.  So I was planning to build around those specifications.
Regardless does that width include just the seat or the arm-rests and everything?
Modern day, I have absolutley no idea how it was back in the 80's, although having a sit in 70's airliner at museum I found it wasn't much different.  You're only going to get a rough idea of size anyway, so I'd take it on the basis of 17 inches.  If you increase the seat size to a slightly more comfortable 18.5 inches, it shouldn't make much of a difference to the overall size of the aircraft.
KJ_Lesnick
Mossie,
QuoteModern day, I have absolutley no idea how it was back in the 80's, although having a sit in 70's airliner at museum I found it wasn't much different.  You're only going to get a rough idea of size anyway, so I'd take it on the basis of 17 inches.  If you increase the seat size to a slightly more comfortable 18.5 inches, it shouldn't make much of a difference to the overall size of the aircraft.
I'll go with 18.5 for the time being.  Regardless, does that 18.5 inches include the arm-rests or not?
