avatar_ysi_maniac
Technical question
Started by ysi_maniac, October 09, 2009, 05:55:50 AM
Planes designed for long range use to have big wing.
What is the best, increasing wingspan or increasing wing area?
Thanks!
Carlos.
Best for increased range is to increase the wingspan, in other words you are increasing the aspect ratio and the wing is more efficient.
BUT..............
doing that you will sacrifice both speed and manouverability.
The choice is yours.
Of course another way to effectively increase the span is add winglets.
jimB
Fulcrum
Which could lead to another question: did anyone build a what-if fighter jet with winglets???
Fulcrums Forever!!!
Master Assembler
elmayerle
Quote from: Fulcrum on October 10, 2009, 12:01:48 AM
Doesn't quite qualify, but a production FV-12A?
--Jane Wagner and Lily Tomlin
Shasper
Ideally you'll want to increase both the span & the area of the wing so you can have the increase  internal fuel tankage, but it would depend on what type of aircraft we're dealing with.
- Bud S.
Carlos, if what your looking at is purely long range flight, you want to look at aircraft like the U-2, Voyager, Global Flyer, M-17 & M-52, Global Hawk.
For a combat aircraft, a wing like Canberra's might be a good option, had a combination of moderately long span with large area.  It had a long range & surprisingly good maneouvarbility for an aircraft of size.  Had a slightly unusual combination of straight inner section, trapezoidal outer section.
If it's a fighter, maybe a delta wing?  It's a compromise, but deltas can hold plenty of fuel.
The Yak-130 prototype
Quote from: B787 on October 10, 2009, 07:18:56 AM
Technically not a fighter, but still close.
At a stretch (and it is a very long stretch), one could say the F-4 Phantom with the upturned outer wing sections.
Quote from: GTX on October 10, 2009, 12:16:35 PM
Now, military aircraft with winglets:
C-17
C-135
C-32
C-37
C-40
Any more?
