avatar_buzzbomb
BAC Sea Canberra -- Finished
Started by buzzbomb, November 29, 2009, 10:01:12 PM
Sorry guys.. a bit overwhelming this time of year and have not got much done.
However thanks for the great feedback and using some of it as we speak
Firstly here is what I have done
Firstly the kit is short moulded in a lot of spots and some patching work will have to be done
General layout with the new radar nose.. sort of Buccaneer, but actually a 1/48 Skyraider drop tank. Blue Parrot Radar works for me.
Side view showing new profile. I am going back to the normal B1 type canopy, I had an old vacform conversion around to convert the B8 back to a B1 during the absence of the Airfix B1 kit years.
... and finally.. bigger donks! Perhaps Spey's.. maybe Conway's.. but bigger anyway. Cut away the old engines and still using the left over bits of Skyraider Drop Tank new, bigger exhausts and intakes
Next is figuring the undercart and whether to have bomb bay open or not and whether to fit a Red Beard Nuke or just freefall .. then the other bits that need attention.
This part of a build like this is 180 grit time so some much finer finishing still to come.
Now how does anti Flash white/subdued markings grab you for colours.. a bit boring perhaps ??
Cheers Brian T
Looking good! For a paint scheme, how about a variation on the classic RN camo, but with a twist? Take the Suez-era scheme of Sky with EDSG top surfaces, but replace the Sky with anti-flash white and the anti-flash roundels on the white surfaces? That would look really interesting IMO. :)
Finally got some tool time
Although I am not entirely happy with the way this is going. Some of the fill/contour blending is not playing to the rules and looking a tad ordinary.
We shall see
Here is what I do have
Cockpit, back to side by side seating
Fleshed out the undercarriage bays, bigger beefier gear
General view of the new nose contour. Considering the RN used the Canberra with the Buccaneer nose.. it looks very similar. Maybe that is what is not looking right.. it has been done before. I suppose the wing fold could be a logical extension of that version
Given it a goof coat of primer and now even less impressed.. too many imperfections around joins.  More bog required.
I think its because the nose looks a little aenemic with that tiny radome.  But otherwise its awesome work, and I think you should plough on with it :thumsbup:
Very interesting to see the wings folded on this.  Will this build continue on past the GB deadline?  Or can you still get it done by Feb. 01?
If an extension is required ... some weeks will be no problem. :thumbsup:
Daryl J.
Pointy nosed Canberras.....mmmmm.   :thumbsup:
Daryl J.
The pilot and nav better be VERY friendly with them both jammed together like that.  :lol:
AFAIK the crew of a T4 couldn't eject because the seats were too close together, and they had a goldfish bowl canopy!
Oops, sorry, that should read pilot and OBSERVER, it's an FAA aircraft after all!
Daryl J.
I think the nose had a very 'British' look about it.
Best to you on the PSR.
Daryl J.
Well.. it is what it is
I didn't quite get the vision my head had, but close.
I went for the standard early mid 60's Dark Sea Grey over white scheme with normal roundels, which fits the era
There serials are actually off a Hercules.. but first in first served in this time line What if.
The wing fold is a variation on the asymetric fold like the Grumman Tracker has.. it does save quite a bit of room
To be sure, to be sure we can throw a fully laden Canberra off.. optional JATO pods
Lengthed Nose gear, a la Phantom (but before of course :lol:) for angle of attack
Closer look at the wing fold layout (and some dodgy painting)
So thanks for the encouragement over the course of this and I will put some shots into the finished thread in a day or two. Because while folks in the Northern Hemisphere are freezing.. we are sweltering down here and it is just to icky to do much
Cheers
Brian T
Brian, that is seriously IMPRESSIVE!  :cheers: :thumbsup:
Well in the Forum tradition of 'If all else fails Whiff a Canberra' and it works a treat. Nice one.
beowulf
that really works well......bravo  :thumbsup:
allergic to aircraft in grey!
very nice, like it very much.  Good choice for paint job.
