avatar_renax
VIRULAN long range heavy fighter
Started by renax, December 21, 2009, 07:02:28 AM
renax
I first posted in "secret projects" but one  told me
Wha-if was more in the subject, so here I am...
this model was made for a comic; (as a drawing help)
The Virulan mission is to escort bombers of the "Bison" class.
I'll add more details later.
the model base is revell's arado.
Arc3371
Geoff
Quote from: renax on December 21, 2009, 07:02:28 AM
<...> I'll add more details later. <...>
I certainly hope so. Looks great indeed. The Luchs-based (?) maintenance vehicle also looks rather interesting.
renax
#5
Comic page is here:
http://www.sharkit.com/alterra1/sanctuaire/sanctuaire.htm
(mail me to renaud@sharkit.com and I send you the PDF file)
The Luchs-based (yes!) maintenance vehicle badly I have only about one picture...
The base kit is the revell arado 555;
The wing is the same as revell kit but there are some modifications:
-engines are now in the fuselage, with leading edge air intakes;
(model engines are two 1/48 jumo 004)
-trolley is mainly home made, with spare sprue.
landing gear have been withdraw
Virulan landes on with skids, with empty tanks only...skids wont stand a heavy loaded plane.
on the shot below the four big JATOs land on help can be seen
Everything has been done to increase the range.
larger picts here:
http://renax-sharkit.blogspot.com/2009/12/virulan-long-range-heavy-fighter.html
(its my blog, here I stock the picts, more are to come.)
beowulf
allergic to aircraft in grey!
thedarkmaster
Quoteooo...i like that!.....nice one
yes it is isn't it  :wub:  :wub:
renax
the model was to avoid to do too many perseptive drawing work,
so it does not look like a nice display model,
only a grey primer paint layer.
On the pict the ladder is 1/48...
Wrong for a display model but enougth for a drawing help....
(large picts: http://renax-sharkit.blogspot.com/)
bobbo
Wow!!  Simply WOW!
Could it possibly become a Sharkit kit?  Please??
bobbo
renax
A sharkit ?
its too big to be casted in resin;
maybe something like a conversion,
as the revell kit is,
as long as I know, not difficult to find.
but make molds and all the things
(masterig parts is very different from doing a scratch, and an instruction sheet must be done...)
need at least a little serie of about 20 copies.
so the hope is thin...
below: the turret, 2 guns top and 2 down.
Arc3371
renax
Comic page is here:
mail me to renaud@sharkit.com and I send you the PDF file;
(its free  but a bit heavy)
you can also look the teaser here on youtube:
http://www.youtube.com/user/renorenax#p/u/7/gSsCgafRA3I
I'll remain on the Virulan on this topic,
but maybe Ill open another one about the comic (not to mix everything)
(the comic is an Uchronian/Alternative History subject)
pictures with turret views:
the gunner is in the turret, but this is not done on the model.
Guns would be 30mm "long"...
both up and low "half turret"
intrados:
(note the retracted landing skids)
Just call me Ray
Stupid question, but...you are going to finish it, right?
Also if it's not too late or too much of a bother some fixed guns in the nose would be cool  :thumbsup:
It's a crappy self-made pic of a Lockheed Unmanned Combat Armed Rotorcraft (UCAR), BTW
Even Saddam realized the hazard of airplanes, and was discovered hiding in a bunker. - Skydrol from Airliners.net
