avatar_renax
VIRULAN long range heavy fighter
Started by renax, December 21, 2009, 07:02:28 AM
renax
In fact
I will not finish it,
I did it only for shots.
also the time to finish it,
I could make a master for a little new kit,
and there are so many new kits to be done
but it could be finished by someone else,
sometime it happens.
(I am just asking myself if I dont need it for more shots, the comic being not ended).
for the nose guns, there is all place not in the nose but in the sides.
I thought the crew was two, one pilot and the gunner/radio/navigator
(at least its how it is in the comic)
but there are two seats in the nose(one copilot/radio/navigator)
Interesting indeed...I predict someone here will attempt to emulate your concept.
raafif
Hi Renax, -- you won't finish this beauty ?? pity, it's a great one ! but then you've been impressing me with your stuff for 30 yrs -- will you do a newer version (1/24th scale please) of that one-wheel desert biker I saw in the early 1980's ??
renax
Thank you....
Well rather than finished the Virulan
(wich is finished for the purpose I built it in fact)
I have done something else with the time....:
http://www.sharkit.com/sharkit/n9jet/n9jet.htm
mail me direct (renaud@sharkit.com)
for the one-wheel bike, I am not sure the one you are talking about.
I have also put some "old" works here:
Northrop N9 V2
http://www.whatifmodelers.com/index.php?topic=26886.new;topicseen#new
Bao_1996
Quote from: renax on December 23, 2009, 03:17:46 AM
Comic page is here:
http://www.sharkit.com/alterra1/sanctuaire/sanctuaire.htm
mail me to renaud@sharkit.com and I send you the PDF file;
(its free  but a bit heavy)
you can also look the teaser here on youtube:
http://www.youtube.com/user/renorenax#p/u/7/gSsCgafRA3I
I'll remain on the Virulan on this topic,
but maybe Ill open another one about the comic (not to mix everything)
(the comic is an Uchronian/Alternative History subject)
pictures with turret views:
the gunner is in the turret, but this is not done on the model.
Guns would be 30mm "long"...
both up and low "half turret"
intrados:
(note the retracted landing skids)
I think It was the turret fighter like some Boulton Paul projects.Is that right ?  ;D
renax
I dont know about Boulton Paul project turret close to this one,
I am very curious to see picts if you have some.
In the Virulan case the turret has a top part and a low part,
operated by a single shooter.
There must have been some turret with this configuration but I have no example in mind right now....
large pict: http://renax-bd.blogspot.com/2009/05/toujour-les-solitaires.html
Bao_1996
Quote from: renax on February 18, 2010, 07:30:11 AM
These Boulton Paul  projects I found from Flitzer profiles.They are P97b,F11/37.The pics are too small to see them.
renax
Does not as both "up and down" turret....
In fact I have no example in mind.
some good things here:
http://bayourenaissanceman.blogspot.com/2008/07/weekend-wings-25-air-gunners.html
Bao_1996
Can I ask what was the mission of the Bison sub in this comic?
renax
#26
you mean this submarine:
(http://www.sharkit.com/alterra1/sanctuaire/sanctuaire.htm)
or the Bison bomber (soviet Myasishchev M-4) that appear at a time in the comic ?
Bao_1996
Quote from: renax on February 22, 2010, 03:31:01 AM
I mean the submarine in the comic.
renax
This submarine
(names the "RAGE")
carries annular-winged airplanes comparable to the SNECMA C-450 Coleoptère
in missile-like compartiments.
One of her mission is to intercept bomber raids as they cross the ocean.
Below is a 1/72 model.
(http://renax-sharkit.blogspot.com/2010/02/le-sous-marin-rage.html)
Bao_1996
#29
Could u tell me the time of the comic like in WW2 or post war.
