Main Menu
avatar_John Howling Mouse
SP-51 Snowstang
Started by John Howling Mouse, December 26, 2009, 04:33:26 PM
Quote from: Ian the Hunter-Gatherer on March 13, 2010, 11:26:28 AM
I think I can see where this is going, and I'm really looking forward to it  :thumbsup:
I think so too.....
Time for some pics of the skis in progress.  After all, snow (and how to deal with it) is the whole point of this GB!
Started with a paper test cut-out that looked okay so I moved on to cutting and shaping some 40 thou styrene sheet.  By slicing halfway through, I created a bend-line where I wanted the ski to be angled (front and back).  In these pics you can see one ski as a straight slab and the other with the ends bent up.
Underneath, I knew filler would not be enough to support the grooves caused from the cutting and bending so I used Evergreen styrene strips as filler-ribs instead:
Add some handcut bits of styrene for details:
Put it altogether and you end up with, well, this, I suppose:
Did you think I forgot about the tailwheel?
While all that progress was going on with the skis, I had to build in some support armatures on the landing gear to attach those skis.  You have to look close to see the extra arms on both sides of the wheels.  They culminate in little shock-absorber pads.  I think.
To break up the monotony of the ski-building, I also built some rockets from the Monogram P-47 Razorback kit.  I drilled out the ends to thin down the rocket tubes' walls and make the holes deeper, more realistic.  The kit's line drawings seem to contradict their own supplied photos of the real thing so I reversed the rockets to match the photos rather than the line drawings.  Maybe the Soviets have different ordnance in this Whifstory.
Want to see what the skis look like all painted up and weathered?  There's even miniature "snow" on them now:
Just giving us a sneak-peak of the camo! ;)  Skis are are a work of art Baz! :wub:
Ed S
Great work on the skis.  This is looking great.
Ed
An artisan at work..... Fantastic, simply fantastic work.
Quote from: Mossie on March 21, 2010, 01:49:19 PM
Heh, heh, yes, I am big tease.  It's called камуфляж снежинки or "snowflake camouflage."
Those skis and their fittings looks very realistic! :thumbsup:
Why the grooves? Because you can and because they improve longitudinal stability on take off and landing runs.
That's some serious ski action there, Mr Howling Mouse!
It's always a treat to see your amazing detail work!
:thumbsup: :thumbsup:
Oh look, winter has decided to make a comeback this morning.  Good for diorama backgrounds!
After excelling at styrene and paint, now he also controls the weather to suit his diorama background needs.  :o
I have been rendered speechless once again to describe the talent I see on display. Bravo!!
Radish
Fabulous work......just brilliant stuff :bow: :bow: :bow:
Only you would make a pair of 1/48 skis into miniature works of art :bow:
