avatar_kitnut617
Wide Body Avro Atlantic
Started by kitnut617, January 11, 2010, 10:40:29 AM
For a tanker, perhaps a Canberra XL? Use a large center fuselage, fitted with the Canberra nose and tail. Extend the wings, and fit the Harriers inside the wings like you VTOL Canberra?
Bigger Thomas, much bigger.  I'm thinking of a Nimrod size STOVL/STOL, VC-10 size  Victor size -----  :wacko:  not a Canberra shape at all but something that exists RW to be converted in my AW
Quote from: kitnut617 on January 12, 2010, 07:27:29 AM
Mi-26 fuselage with wings of some sort?
Canadair CL-215/415?
Noratlas?
C-119?
Robert, how about a 1/48 Dakota wing?  I sounds daft at first, but it actually works quite well as a swept wing.  It should work well if you make a cut to increase the angle of sweep.
Here it is split into two parts at different angles, 1/72 wing on a 1/48 subject.  Only thing is it might be a bit thick for your project, but you could always sand the two halves downn?
I like that Mossie,
Where have you been hiding that little gem :wub:
Chris.
Lots of food for thought here guys, thanks.
Simon, yes, where have you been hiding that neat looking creation -----
It's been going three years nearly, from the last Secret Santa GB.  I dropped the canopy, stepped back where it couldn't possibly have fallen.... :banghead:  I've not been sure what to do with it since then.
Original build thread:
http://www.whatifmodelers.com/index.php/topic,14352.0/highlight,indiana+jones.html
Quote from: PR19_Kit on January 11, 2010, 11:29:33 AM
You want it SWEPT?  :o
I've done a bit of investigating, an Airbus A318/320 wing has about the same MTW capability as the Transall wing, and I can get an A320 in 1/72 from Welsh Models, I've got a Transall already.  I've decided to go this way with the two 1/48 Harrier fuselages instead of doing the Nimrod.  I've also got a spare KC-10 conversion too.
I want to see what you're going to do with all the bits left over AFTER you've done this one!  :lol:
So you want to mount the A318 wing to the top of the Transall? Sweet...
Quote from: PR19_Kit on January 21, 2010, 04:18:11 PM
Hadn't given it a thought Kit ---- yet   ;D
Mind you, chatting with Denzel at Welsh Models when I was after some bits & pieces, I found he will not break up any of his kits just for certain parts, but he did say that if I bought all the resin parts from a kit, or all the vac parts etc, he would sell them to me but what he doesn't want is a pile of parts that can't be used just lying around his shop.
Quote from: B787 on January 22, 2010, 05:32:21 AM
:thumbsup: :thumbsup:
Make sure the wings droop a little though :thumbsup:
A Gloster V/STOL transport project that may be of interest.
Two Pegasus and ten lift engines.
Cheers, Jon
Yoikes Jon, another great find.  I'm trying to come up with something that doesn't have all the extra lift engines, I just don't see the point of hauling around all that dead weight for 98% of the mission.  Which is why I'm liking the idea of the vectored thrust RB-211 idea you banded earlier.  Mind you, if the sound of the Rotodyne killed that project, I can't imagine what might have been said if one of these tried landing down-town.   :lol:
