avatar_Aircav
Help with a E.10
Started by Aircav, February 11, 2010, 12:04:39 PM
Okie dokie, which of these two pitcures look better for the co-axial gun placement, A or B
A
1 (4%)
B
24 (96%)
Total Members Voted: 24
Aircav
I'm having a little trouble in deciding which looks the best for the co-axial postion and would like your thoughts.
A)
B)
Many thanks
Steve
Sir Sydney Camm
Vertical Airscrew SIG Leader
frank2056
In position "A", the gunner is going to have a hard time aiming at anything to the left of the tank. In "B", he'll have a better field of view.
I did something similar with a Gatling gun.
What will the main armament be? The E-10 is rather small, IIRC, so the placement of the main gun should probably determine where this secondary MG will be put.
Aircav
Hi
as you can see the sight is next to the MG, which will be the main armament and as the cases come out of the gun on the right then the gunner will sit on the left towards the centre of the vehicle
Steve
Sir Sydney Camm
So no further hull-mounted ordnance? Then put it in position B. :thumbsup:
Aircav
Just the MG as she'll be a ARV  ;D
Sir Sydney Camm
redram
I vote A, the gunner and the driver would have more space to work.
ARV? Doors on the roof, little crane? Sounds interesting.
Aircav
Yeah, I'm leaning towards A as well, I'll see as the project goes on, got some more parts to add before I decide for sure.  ;D
Sir Sydney Camm
Quote from: Aircav on February 12, 2010, 10:17:43 AM
And here I was thinking you were going to do an APC...
Think B would make it easier to reload and increase the field of fire.
Aircav
Quote from: GTX on February 12, 2010, 01:39:02 PM
Got that planned for a E25  ;D
Sir Sydney Camm
Aircav
Quote from: philp on February 12, 2010, 01:58:05 PM
I'm still not set on the postion so I'll build some of the interior and see how it goes.
Sir Sydney Camm
Aircav
The belt on a MG-34 feds in from the left side so the waste case bag would be on the right next to the side bulkhead.  ;D
Sir Sydney Camm
Aircav
Here's three pics of the second E.10 I'm on with this time test fitting a 10.5cm assault gun as the main armament.
Sir Sydney Camm
