avatar_ysi_maniac
Enzian
Started by ysi_maniac, February 18, 2010, 06:49:25 AM
Currently thinking in a 1/72 model using a Hasegawa flak 18
http://www.walter-rockets.i12.com/missiles/enzian2.htm
http://www.luftarchiv.de/index.htm?/bordgerate/abwurf.htm
Does any of you have info about tractor and other land devices?
This page is on the Schmetterling, however it should give you a good idea about how they intended to service and use the AA missiles.
http://deutscheluftwaffe.de/archiv/Dokumente/ABC/f/Flakraketen/Hs%20117%20Schmetterling/hs%20117%20schmetterling.html
As far as tractors are concerned, most likely their standard 3/4 track prime movers.
Do you have the kit.
Think the Planet Models kit comes with the launcher.  The Condor kit has just the missile.
The Hanomag Sdkfz 7 should be plenty powerful enough to tow it.
;D For the whiffing shake: ;D
I think that launching base would be usually static. This way, missiles could be transported by a simple Opel truck, perhaps equiped with a crane. IMHO operating this device could not be the similar to a FlaK 88mm gun.
BTW Has anyone built the Planet models kit?
I have the Condor one.
